Page 1 of 3 1 2 3
Anyone shoot A4 silver recently? #3003870
01/10/22 04:56 PM
01/10/22 04:56 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Recent talk about discontinued toners doesn't sound like good news for our community as a whole.....
Working on my Street/Strip '69 GTX that you may (or may not) have seen before.
A little about me:
I'm about learning and doing.
My first paint job was this car back in the early '90s, I did it in black lacquer which has all mostly failed by now as the car spent lots of time outdoors.
I am replacing alot of metal and so forth.
To be honest, the car will probably never be a true restoration as long as I own it... things have been enhanced quite a bit, but I'm the process of trying to
plan and figure out what is what, and am considering maybe returning it to the original color.
The inside of the trunk lid shows the original paint which is A4 silver (attached)
Trying to figure out if the current off the shelf PPG formula still considered pretty close (as it was, not too long ago), or
if would I be better off trying a Spectrometer instead.
I may end up changing the color to something that is a little less painful to research but would like to try to give the original
A4 a chance with a sprayout, if I can acquire a small enough quantity to make it reasonable.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3003927
01/10/22 08:52 PM
01/10/22 08:52 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1968 was the last year that paint code "A" - an extra-cost hand-buffed "silver metallic" was available
1969's "A4" (EA4) was simply "silver metallic" at Plymouth & Dodge and "platinum metallic" at Chrysler & Imperial a STANDARD color choice w/o the extra cost
Re: Anyone shoot A4 silver recently? [Re: 6bblgt] #3003931
01/10/22 09:05 PM
01/10/22 09:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My 69 Dart was painted A4 silver 5 years ago.
Last year a buddy of mine( retired auto body guy) painted under the hood A4 when i had the old motor out.
PPG is the by far best way to go regards this color.
When its right, it has a very light green tint to it in certain light.
https://www.forabodiesonly.com/mopar/threads/nice-picture-some-photographer-took.500454/
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anyone shoot A4 silver recently? [Re: 6bblgt] #3004203
01/11/22 04:56 PM
01/11/22 04:56 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
The word "buffed" has now been removed from the original post to take care of that problem.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: B3422W5] #3004204
01/11/22 04:57 PM
01/11/22 04:57 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks Don.
If it was good as recent as last year, maybe it won't be a problem to get my hands on a small amount of basecoat that will hopefully look pretty close.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3004309
01/11/22 08:34 PM
01/11/22 08:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
There are enough silvers out there nowadays that it shouldn't be too hard to get a close match that can be tinted if necessary.
Great color, not often seen.
Re: Anyone shoot A4 silver recently? [Re: topside] #3004519
01/12/22 12:32 PM
01/12/22 12:32 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My 66 has A1, BUFFED, says so on IBM card. Might not be relevant to 68-9 but they did do it
Re: Anyone shoot A4 silver recently? [Re: topside] #3004544
01/12/22 01:43 PM
01/12/22 01:43 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Agreed...
Main drawback is I'm doing this 100% myself and do not have the multiple shop hookups for custom tinting.
Whatever I get will likely be "like it or try something else".
As expensive as name brand basecoat is these days, I'd really hate to add on anything custom on top of it.
Very tempted to try other brands as well and need to strategize how I want to go about this deal.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: cudaman1969] #3004545
01/12/22 01:47 PM
01/12/22 01:47 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
No big deal, I've got plenty enough problems already without dwelling on that kind of thing.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3004567
01/12/22 02:29 PM
01/12/22 02:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
OK, best thing in that case is to look through the local paint jobber's paint sample books.
Bring an example of the color you want.
I like to compare/check in outdoor daylight as well as indoor light.
I recall the "buffed silver" deal, my guess is Chrysler felt obligated to get a better reflection.
Most light metallic enamels in that era didn't have the reflection of darker or non-metallic colors, especially silver.
Knocking down the texture a bit helps with that, of course. Plus, marketing !
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3004578
01/12/22 02:46 PM
01/12/22 02:46 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I took a painted part to the PPG paint guy to match, he said didn’t need it then mixed up a sample. Perfect match.
Re: Anyone shoot A4 silver recently? [Re: cudaman1969] #3004603
01/12/22 03:25 PM
01/12/22 03:25 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
That helps. How long ago?
I still might get a Spectrometer reading just to see what happens, but admit I don't much feel like dragging that boat anchor heavy trunk lid into the store.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3004678
01/12/22 06:35 PM
01/12/22 06:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Last spring
Re: Anyone shoot A4 silver recently? [Re: cudaman1969] #3004692
01/12/22 07:07 PM
01/12/22 07:07 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Not long, then...great
Should hopefully still be able to get it! thank you
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3004763
01/12/22 11:01 PM
01/12/22 11:01 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The guy is good, he mixed up the perfect purple and green for my future cars paint 73 Barracuda and 69 Barracuda, 64 is black and Duster is white so no biggy on them, A1 goes on the 66, single stage like factory. Others are CC
Re: Anyone shoot A4 silver recently? [Re: cudaman1969] #3005075
01/13/22 09:46 PM
01/13/22 09:46 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Just go to the PPG dealer and get a pint of the correct code and bring it home and do a couple of spray outs. Done! It ain't rocket science.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Anyone shoot A4 silver recently? [Re: MOPARMIKE69] #3005282
01/14/22 03:21 PM
01/14/22 03:21 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Eventually I will do exactly that.
Lots of work to do ahead of it though.
Until that time comes, I'm going to ask questions. Enjoy.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3079942
09/23/22 12:37 PM
09/23/22 12:37 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
If anyone cares, (however very unlikely that may be), here's the sprayout from earlier this week.
I've taken the time to move it around in different light, and love the color. I'm going for it. Glad I gave the original color a chance.
Rich H.
Esse Quam Videri
Re: Anyone shoot A4 silver recently? [Re: ZIPPY] #3079980
09/23/22 01:58 PM
09/23/22 01:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Great color, and not common.
Always liked A4 - to me, it's kind of "upmarket" and subtle - but haven't owned or painted a car that color yet.
Re: Anyone shoot A4 silver recently? [Re: topside] #3079981
09/23/22 02:01 PM
09/23/22 02:01 PM
Kirkland, Washington
Pacnorthcuda Offline
That’s Winchester Grey right? I always thought a black vinyl top pared well with that!
Page 1 of 3 1 2 3
