Re: Show me your hemi builds [Re: 5carguy] #3003905
01/10/22 08:06 PM
01/10/22 08:06 PM
Which early hemi block did you choose and how big?
I got addicted to them in the early to late 1960s up
Converted to the 426 street Hemi on the first gas crunch in the 1970s boogie
I wish I had the foresight to buy as many of the street Hemi cars on the use car lots that I could have afforded for $300.00 to $1000.00 each back then shruggy I didn't realcrazy whiney
Re: Show me your hemi builds [Re: Cab_Burge] #3004080
01/11/22 11:42 AM
01/11/22 11:42 AM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
528 all aluminum hemi . 692 hp and 612 tq.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Show me your hemi builds [Re: Cab_Burge] #3004254
01/11/22 06:04 PM
01/11/22 06:04 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
It's a 392 .030 over.Dyers 6-71 blower with twin 780s
Re: Show me your hemi builds [Re: 5carguy] #3004349
01/11/22 10:01 PM
01/11/22 10:01 PM
Do you know which casting the block is, RR, A-1 or the other one?
The reason I ask is I've own all 3 and would use the A1 casting with the stronger main webbing for the blower motor up
Re: Show me your hemi builds [Re: Cab_Burge] #3004595
01/12/22 03:08 PM
01/12/22 03:08 PM
moparx Offline
moparx  Offline
according to one book i have, the A-1 casting indicates the block was cast at the foundry at 8 Mile Road & Mound Road.
H H indicates the Highland/Hamtramck foundry [mostly for Dodge vehicles/trucks]
the CWC mark was the Chrysler Windsor Canada foundry.
beer
Re: Show me your hemi builds [Re: Cab_Burge] #3004611
01/12/22 03:38 PM
01/12/22 03:38 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
I built a 572 C.I. pump gas street Hemi motor for a local customer for his 1971 Challenger, he will drive it to local cruise and car shows.
I used a World block bored to 4.500 and a 4.500 stroke crankshaft, 10.8 to 1 compression, dual EFI throttle bodies on a Stage 5 single plane dual throttle body intake manifold FHO rocker arms, solid roller EFI street cam.
Mopar 1970/1971 stock street hemi oil pan and pickup, Holley EFI and ignition.
It made 799 HP at 6500 RPM, and it made 704 Ft. Lbs. from 3500 RPM to 732 peak torque at 5400 RPM with 732 Ft. lbs. with 705 Ft. lbs. at 5900 RPM on 91 octane CA pump swill.
it should be a real hoot to drive on the street boogie devil
I can say i like the sounds of this power level.
Re: Show me your hemi builds [Re: Mally69] #3004642
01/12/22 05:08 PM
01/12/22 05:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Thats what 25 to 30 grand will buy you.
Re: Show me your hemi builds [Re: NITROUSN] #3004693
01/12/22 07:14 PM
01/12/22 07:14 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Correct me if I'm wrong Cab, but isn't this that same engine?
I thought I remembered on one of the old threads Nedbal jumped in and posted this video, but he doesn't seem to come to this board anymore.
Rich H.
Esse Quam Videri
Re: Show me your hemi builds [Re: ZIPPY] #3005208
01/14/22 11:31 AM
01/14/22 11:31 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
Either way the EFI wont be the route i take. Id rather use a carb. One big part of the budget is paying someone to assemble it. I can def assemble my own which should save me some loot.
Re: Show me your hemi builds [Re: Mally69] #3005236
01/14/22 12:49 PM
01/14/22 12:49 PM
moparx Offline
moparx  Offline
so when it's together, you stick it in my car to "break it in" ? whistling biggrin
beer
Re: Show me your hemi builds [Re: Mally69] #3005277
01/14/22 03:12 PM
01/14/22 03:12 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Same.
Re: Show me your hemi builds [Re: moparx] #3005388
01/14/22 10:28 PM
01/14/22 10:28 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
beer
Id come over and help put it, just buy the parts
Re: Show me your hemi builds [Re: Mally69] #3005578
01/15/22 02:24 PM
01/15/22 02:24 PM
moparx Offline
moparx  Offline
ratz............i just knew there would be a catch................ laugh2
beer
Re: Show me your hemi builds [Re: moparx] #3006022
01/16/22 08:26 PM
01/16/22 08:26 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
beer
whistling haha
Re: Show me your hemi builds [Re: ZIPPY] #3006060
01/16/22 09:34 PM
01/16/22 09:34 PM
Your correct, that is the same motor up
it is still not in the car due to the dang body shop not finishing the paint and body work three years later puke rant down
Re: Show me your hemi builds [Re: Cab_Burge] #3006521
01/18/22 01:28 PM
01/18/22 01:28 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My little ole 528" street car. 2 kits just in case I am running late for work.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Show me your hemi builds [Re: Mally69] #3008305
01/23/22 07:52 PM
01/23/22 07:52 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
