could this be oil in my coolant? #300283
04/26/09 05:05 PM
04/26/09 05:05 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
just gone through my cooling system, changed to an alum rad and new upper hose. my car runs great and the oil is coolant free but the antifreeze that i drained from the rad and from the recovery tank (closed system with catch can) has a slippery feeling froth that sits on top of the coolant. is this normal? and if not, can oil get into the coolant without coolant getting in the oil? like i said the car runs strong. 440/727 stealth heads, street with some strip.
Re: could this be oil in my coolant? [Re: dirtybee] #300284
04/26/09 05:36 PM
04/26/09 05:36 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Antifreeze contains lubricant for the water pump bearings and seal. Some slipperyness is normal. That's why you can run into trouble running straight water, the bearings have no lube.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: could this be oil in my coolant? [Re: GO_Fish] #300285
04/26/09 08:26 PM
04/26/09 08:26 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you are getting oil in the coolant, if there is any quantity at all, the coolant will turn a crappy chocolate color. At least that's what happened to me on a 2.2 with a cracked block and a 360 with a failed intake manifold gasket. If you are still concerned, any heavy equipment dealer, Cat, John Deere, Case, etc. can probably test for oil contamination.
