no spark in "run" position. MSD..FIXED!! Thanks!! #300209
04/26/09 02:04 PM
04/26/09 02:04 PM
Medford OR
FrankenScamp Offline OP
Medford OR
just wondering where to start w/the test light.
I have NO ballast resistor, running an MSD 6AL. Where should I have juice with the key just "on"?
Thanks!.....Shawn
Re: sparks when cranking, no spark in "run" position. MSD.. [Re: FrankenScamp] #300210
04/26/09 02:08 PM
04/26/09 02:08 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
The blue with the white trace and the brown must be splice together to power msd.
Basically the IGN 1 and the IGN 2 from your key switch.
Or the Dark blue and the brown wire at your resister
Ign 2 which is what you have hooked up to the MSD right now and is giving it power when you crank only.
You also need IGN 1 to power the MSD (when you release the key) and have it in position IGN1
Re: sparks when cranking, no spark in "run" position. M [Re: HealthServices] #300211
04/26/09 02:25 PM
04/26/09 02:25 PM
Medford OR
Medford OR
The MSD is under the dash and I have the brown wire going straight to it from the column. The blue is running its normal path to the alt.
should I still connect them together some how? Should I have power at the box with the key in the run position?
Thanks for your help...
Re: sparks when cranking, no spark in "run" position. M [Re: FrankenScamp] #300212
04/26/09 02:29 PM
04/26/09 02:29 PM
Medford OR
Medford OR
Just saw your "EDIT", lemme go give it another look....
Re: sparks when cranking, no spark in "run" position. M [Re: FrankenScamp] #300213
04/26/09 02:35 PM
04/26/09 02:35 PM
So Cal
So Cal
I colored the wires so you can read it easier. Download it as I will remove after a week
http://i69.photobucket.com/albums/i69/bluemandm/mopar/72DartA.jpg
http://i69.photobucket.com/albums/i69/bluemandm/mopar/72DartB.jpg
For a 72 dart. Good luck
I have to run out of town for a while hopefully someone else can help if you still don't have it.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: sparks when cranking, no spark in "run" position. M [Re: HealthServices] #300214
04/26/09 02:44 PM
04/26/09 02:44 PM
Medford OR
Medford OR
Thank you.... I think I get the idea now.
Re: no spark in "run" position. MSD..FIXED!! Thanks!! [Re: FrankenScamp] #300215
04/26/09 08:18 PM
04/26/09 08:18 PM
Medford OR
Medford OR
Thank You Allen......All better now.
Re: no spark in "run" position. MSD..FIXED!! Thanks!! [Re: FrankenScamp] #300216
04/26/09 08:25 PM
04/26/09 08:25 PM
So Cal
So Cal
