Clutch issue #300126
04/26/09 01:51 PM
04/26/09 01:51 PM
Iowa
P
plumcrazyb Offline OP
P
Iowa
Everything is hooked up, but the clutch won't disengage with the pedal to the floor, plenty of resistance. Any obvious things to check? thanks!
Re: Clutch issue [Re: plumcrazyb] #300127
04/26/09 02:25 PM
04/26/09 02:25 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Is it adjusted correctly?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Clutch issue [Re: plumcrazyb] #300128
04/26/09 04:34 PM
04/26/09 04:34 PM
Buzzardbreath Wyoming
BigBird Offline
BigBird  Offline
Same thing happened to me once. It ended up being the pivot tube had split and would flex enough that it would not disengage. It looked fine until you had someone step on the clutch while you were watching the linkage, then the split would show up. Worth a look.
Re: Clutch issue [Re: plumcrazyb] #300129
04/26/09 11:13 PM
04/26/09 11:13 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Has the car been parked for a while? Sometimes the disc will rust to the plate or flywheel.If so just buzz it down the street accelerate and let off with your clutch pedal down.
Gus
64 Plymouth Savoy
Dana 60
Re: Clutch issue [Re: fourgearsavoy] #300130
04/27/09 11:04 AM
04/27/09 11:04 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I had the same issue with my Wrangler this weekend, has been sitting a couple years due to a leg injury that had the Dr saying "NO driving stick"; started it in 2nd (yeah it rolled while starting) out of teh driveway (it had been backed into the garage) by the 1st street corner it broke loose; so far so good.
