Re: Which small block accessory set-up are you using ?
[Re: topside]
#3011702
02/02/22 08:52 PM
02/02/22 08:52 PM
Posts: 4,989 new jersey usa
11secdart
new jersey usa
My 408 and 367 small blocks .. I run a one wire alternator, stock style water pump and a Moroso crank pulley driven off a single V belt.. tension is adjusted on the alternator like a stock set up
[Re: 11secdart]
#3011819
02/03/22 09:59 AM
02/03/22 09:59 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
My 408 and 367 small blocks .. I run a one wire alternator, stock style water pump and a Moroso crank pulley driven off a single V belt.. tension is adjusted on the alternator like a stock set up Pretty much the same set up here, I made the brackets for my alternator.
