Rv trans in a car #2999292
12/28/21 08:28 PM
12/28/21 08:28 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Any way to add a slip yoke in the driveshaft so I can use a rv 727 with bolt on yoke in a car?
Re: Rv trans in a car [Re: chargers777] #2999331
12/28/21 10:16 PM
12/28/21 10:16 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Many of the 70s Dodge 4x4 trucks also had a bolt on driveshaft at the transfer case. Those had a short shaft with a splined end, and the the back section had the female splined end and went back to the regular U joint at the rear end. Essentially the slip joint was in the front section of the driveshaft. you could use a driveshaft like that in a car. Gene
Re: Rv trans in a car [Re: poorboy] #2999511
12/29/21 01:24 PM
12/29/21 01:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Rv trans in a car [Re: chargers777] #2999624
12/29/21 06:38 PM
12/29/21 06:38 PM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Yes.
Angry white pureblood male
Re: Rv trans in a car [Re: ruderunner] #2999700
12/29/21 09:23 PM
12/29/21 09:23 PM
Nashport, OH
Nashport, OH
Ok thanks.Anything factory I should be looking for?
Re: Rv trans in a car [Re: chargers777] #2999907
12/30/21 01:23 PM
12/30/21 01:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Rv trans in a car [Re: chargers777] #3000029
12/30/21 05:10 PM
12/30/21 05:10 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This isn't Cuba, man. Why make things hard for yourself? The correct parts aren't hard to find.
Re: Rv trans in a car [Re: Kern Dog] #3000286
12/31/21 01:34 PM
12/31/21 01:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The OP wants to use an RV 727 "in a car". Depending on the car, there may be no "correct parts".
Re: Rv trans in a car [Re: John_Kunkel] #3000534
01/01/22 01:53 AM
01/01/22 01:53 AM
Nashport, OH
Nashport, OH
Or truck.These trans are common.I have 2.
Re: Rv trans in a car [Re: chargers777] #3000659
01/01/22 03:04 PM
01/01/22 03:04 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Shooot...I have 5 Big Block 727s out back, a few 904s too. Not sure when I'll use them.
Re: Rv trans in a car [Re: Kern Dog] #3001406
01/03/22 10:54 AM
01/03/22 10:54 AM
scratchnfotraction Offline
kind of use what you got and run what you brung deal.
I have used those short shaft 727s in my 68 dart a couple times. bolts right in and yoke just clears xmember, I then used a 4x4 drive shaft after a cut & balance for the slip yoke/7260 yokes. never had an issue but always ran the slip yoke at the rearend.
Re: Rv trans in a car [Re: scratchnfotraction] #3001542
01/03/22 03:25 PM
01/03/22 03:25 PM
Nashport, OH
Nashport, OH
Thanks for the info.Exactly what I was looking for.Thanks.
Re: Rv trans in a car [Re: scratchnfotraction] #3001708
01/03/22 07:18 PM
01/03/22 07:18 PM
Nashport, OH
Nashport, OH
Wouldn't happen to have a pic would you?
Re: Rv trans in a car [Re: chargers777] #3003568
01/09/22 07:56 PM
01/09/22 07:56 PM
The R.V. came with one, go get it and use it with your stock drive shaft twocents
I'm going to do that, use a R/V short BB 727 tranny in my new drag car, after I get the biggest and strongest front slip yoke out there from my local agricultural H.D. drive shaft maker up
