aluminum heads #2998379
12/25/21 01:23 PM
12/25/21 01:23 PM
wilmington,ohio
O
ohiodemon Offline OP
O
wilmington,ohio
has anyone done a back to back dyno test of edelbrock heads vs. trickflow heads?
i like the looks of the T F heads.
this would be the smallblock heads.
Re: aluminum heads [Re: ohiodemon] #2998386
12/25/21 02:16 PM
12/25/21 02:16 PM
AndyF Offline
AndyF  Offline
On a big block the TF heads are worth a nice chunk of power over Edelbrock heads. I've only tested one set of SB heads and the results were not great. Others have had better luck.
Re: aluminum heads [Re: AndyF] #2998390
12/25/21 02:39 PM
12/25/21 02:39 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
can I tack something on here? I have a couple of Magnum 360s here sitting on the floor (mag 318s too, those are in pieces) and I have 1 known good original head and 2 "maybe's" that haven't yet been thru the machine shop.
Many guys here want straight line acceleration performance, but I am looking at a different purpose... hauling and towing. Would aluminum heads be an a advantage here? or would I be better with cleaned up, ported iron heads?
Re: aluminum heads [Re: volaredon] #2998405
12/25/21 03:51 PM
12/25/21 03:51 PM
AndyF Offline
AndyF  Offline
Talk to Brian at IMM. He'll probably steer you towards some new iron heads.
Re: aluminum heads [Re: AndyF] #2998417
12/25/21 04:33 PM
12/25/21 04:33 PM
wilmington,ohio
O
O
wilmington,ohio
u do the edelbrocks?
i know the trickflows are a better design.
Re: aluminum heads [Re: ohiodemon] #2998553
12/26/21 09:36 AM
12/26/21 09:36 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you are going to run a smallish cam (.550 or under) you won’t really notice a difference in TrickFlow, Edelbrock, speedmaster type of heads.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
