Re: 5.9 Magnum to Ebody 5/6qt Oil Pan- who made it?
[Re: Chargerbee]
#2998811
12/27/21 11:59 AM
12/27/21 11:59 AM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
Back when dinosaurs roamed the earth, in the halcyon days of the 360/380 and 402/435 Mopar Performance crate engines which were based on a production 5.9 Magnum block, standard 360 passenger car pans were used on both. The 402 had a Moroso deep pan and the 380 had a regular replacement 360 pan. The pan on the 380 was sort of similar to this one. https://www.manciniracing.com/ma360cesupa.htmlI'm sure I could probably find the old MP number but the entire older product line appears to be gone so that search would be pointless.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3000992
01/02/22 12:48 AM
01/02/22 12:48 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
No one I am aware of makes aftermarket magnum specific oil pans (meaning front of pan rounded all the way up to block for the magnum one piece pan gasket). A regular LA 360 bolt up using the LA pan gaskets. The rear main seal material is irrelevant. Kevko M302 is "supposed to fit" stock K frames although I have seen a few people cut small notches in the K frame lip.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
