Page 46 of 48 1 2 44 45 46 47 48
Re: Modern Bullitt build [Re: larry4406] #2997248
12/21/21 10:21 AM
12/21/21 10:21 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by larry4406
Nice shop Pat!
I like those lights. What are they?
Big Ass fan is a nice addition.
Jackshaft door operators as well!
What is the size? Ceiling looks to be 12-14'?
Exterior shot?
Keep us posted on your next project.
-larry
LED 4x2 panel lights, I’ll let you know how they work.
https://www.amazon.com/dp/B0849TG3B3/ref=tsm_1_tp_tc
The shop is 48’x32’ with 13’ ceiling just enough room for the tall two post lift.
Thank You!
Re: Modern Bullitt build [Re: Keepat] #2997518
12/22/21 09:19 AM
12/22/21 09:19 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Nice place Keepat!
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Modern Bullitt build [Re: Keepat] #2997870
12/23/21 01:41 PM
12/23/21 01:41 PM
central il.
second 70 Offline
second 70  Offline
central il.
Nice shop Pat!
Exterior shot?
-larry
Thank You!
Hey Keepat I really can't tell on your both your doors but the lower panels on the left door seem to be bent in the middle. I had the same thing and it's the door bending in the middle when it opens. It will end up tearing the panels open. I didn't have a clue since I use the same jackshaft openers you do. I didn't catch it until I unhooked it and operated it by hand.
The fix is to add struts to door. At less that $25 each I just added them to each panel.
Re: Modern Bullitt build [Re: second 70] #2997970
12/23/21 06:09 PM
12/23/21 06:09 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Nice shop Pat!
Exterior shot?
-larry
Thank You!
Thanks for the note, and good eyes! Actually the bottom panel is bent from the previous owner closing the door by stepping on that lip.
My garage door opener man is coming back as soon as I put a coat of paint on the outside of the door to readjust the springs for the new weight of the doors.
Thank You!
Pat
Re: Modern Bullitt build [Re: Keepat] #3015831
02/15/22 10:08 PM
02/15/22 10:08 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
We are registered for the HotRod power tour this June. Kurt in his Bullitt Mustang and me in the Bullitt Charger. I’m excited to hit the open road with both car! It will be about 2800 miles round trip. It’s been about 9 years since going on the tour with Kurt’s Mustang.
Pat
Re: Modern Bullitt build [Re: Keepat] #3015897
02/16/22 06:58 AM
02/16/22 06:58 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Awesome Pat!
Re: Modern Bullitt build [Re: larry4406] #3016157
02/16/22 09:03 PM
02/16/22 09:03 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
That's going to be a fun trip!
DynoDave
Member # 12304
Re: Modern Bullitt build [Re: DynoDave] #3016378
02/17/22 08:16 PM
02/17/22 08:16 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
New shop update. The power is on, floors are polished and sealed, lift is installed, wall cabinets installed, and the heat/air system up and running! I will be installing the base cabinets this weekend. Should be ready for my car projects soon!
Pat
Re: Modern Bullitt build [Re: Keepat] #3016693
02/19/22 07:15 AM
02/19/22 07:15 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Nice shop Pat!
Color me green with envy.
Re: Modern Bullitt build [Re: Keepat] #3016754
02/19/22 12:48 PM
02/19/22 12:48 PM
central il.
second 70 Offline
second 70  Offline
central il.
Pat, I use the Mitsubishi split units in my garage and great room. I spent a little extra and got the H2i hyper heat pump so it would work if weather got super cold. 100% @ 5 and 74% @ -13. Even so they work so much better above 32 and for air. My inside units are the fancy 9K and 18K that work off the 1 outside multi zone 24BTU unit. Is yours multi zone or do you have 2 outside units? Are you using it for heat and air or just air?
These are the units I have. https://skipthewarehouse.com/mitsubishi-mxz3c24nahz2u1-24000-btu-hyper-heat-heat-condenser Great looking garage. Mike
Re: Modern Bullitt build [Re: larry4406] #3017027
02/20/22 08:54 AM
02/20/22 08:54 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Nice shop Pat!
Thank You sir!
Re: Modern Bullitt build [Re: second 70] #3017028
02/20/22 08:58 AM
02/20/22 08:58 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Mike, The Mitsubishi mini split‘s are amazing units so efficient and produce heat in very low temperatures where traditional heat pumps struggle. I have a single 36K unit outside feeding the two 18k air handler‘s
Pat
Re: Modern Bullitt build [Re: Keepat] #3017244
02/20/22 11:50 PM
02/20/22 11:50 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
That new shop is awesome!
Re: Modern Bullitt build [Re: 69Cuda340S] #3018499
02/24/22 02:48 PM
02/24/22 02:48 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I use a lot of Sunpro lights, they are awesome. I’ve not used the flat panels yet. I just put up some of their other shop lights this past fall and already bought enough to do the other bay. They really look good.
The power tour with the bullitt duo is off the hook. Mega kudos on that.
I want my fair share
Re: Modern Bullitt build [Re: 69Cuda340S] #3018612
02/24/22 07:30 PM
02/24/22 07:30 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank You sir!
Re: Modern Bullitt build [Re: SomeCarGuy] #3018613
02/24/22 07:32 PM
02/24/22 07:32 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I am also very happy with the shop lights. Was concerned that they would be too bright so I put them on three different switches.
Thank You!
Pat
Re: Modern Bullitt build [Re: Keepat] #3022722
03/10/22 08:28 PM
03/10/22 08:28 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Just finished reading the May issue of the Mopar Collector Guide and got a cool surprise. On the second to the last page they tell you what’s coming up in the next issue. I see a picture of my car on the top right hand corner with the caption Modernized Bullitt 1968 Charger tribute car. Looking forward to the next issue;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #3022782
03/11/22 12:51 AM
03/11/22 12:51 AM
SomeCarGuy Offline
SomeCarGuy  Offline
I saw that this week and instantly thought of this thread. Pumped to see the write up.
Re: Modern Bullitt build [Re: SomeCarGuy] #3024107
03/15/22 07:07 AM
03/15/22 07:07 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Shop update, All cabinet and countertops are installed. I labeled each cabinet & drawer in alphabetical order using car emblems. The 3 tool cabinets I used engine displacement emblems from Pontiac, Dodge, & Ford. I’m not sure if it will help me remember where stuff is, but I think it looks cool;-)
Pat
https://fb.watch/bMb3anEDWv/
Re: Modern Bullitt build [Re: Keepat] #3024179
03/15/22 11:51 AM
03/15/22 11:51 AM
central il.
second 70 Offline
second 70  Offline
central il.
If I had a 318 emblem I'd send it to you for unmarked drawer.
