ATI super damper with BBC hub #2994808
12/12/21 11:36 PM
12/12/21 11:36 PM
South Dakota
dakotahotrodder Offline OP
South Dakota
Is anyone using the ATI super damper on a big block with the big block chevy hub? That is what my set up is and I am looking for advice on a crank trigger and mandrel for a vacuum pump. I have an Aerospace vacuum pump and got the BBC mandrel but the inside of the mandrel is not machined for the front bolt and washer. Wondering if anyone else has ran into this issue.
Thanks!
Re: ATI super damper with BBC hub [Re: dakotahotrodder] #2994824
12/13/21 01:24 AM
12/13/21 01:24 AM
AndyF Offline
AndyF  Offline
You have to have a machine shop put a pocket on the inside of the mandrel for the crank bolt and washer.
Re: ATI super damper with BBC hub [Re: AndyF] #2994835
12/13/21 05:08 AM
12/13/21 05:08 AM
NC
440Jim Offline
440Jim  Offline
NC
The is the Aerospace Components mandrel for the BB Mopar. It shows the "pocket" to clear the large Chrysler bolt and washer.
Re: ATI super damper with BBC hub [Re: AndyF] #2994838
12/13/21 07:00 AM
12/13/21 07:00 AM
South Dakota
South Dakota
Thanks Andy! I was wondering if that was the route I was headed. Thanks Jim for the picture showing what is done. I will get this done.
Re: ATI super damper with BBC hub [Re: dakotahotrodder] #2994898
12/13/21 01:09 PM
12/13/21 01:09 PM
AndyF Offline
AndyF  Offline
Back in the old days I used to build my own Mopar spline drives just because there wasn't anything on the market that fit a BB Mopar. Then I switched to buying the ATI damper with the BBC bolt pattern and using a Peterson BBC blank. The Peterson blank still has to be relieved, but it is less work than starting from scratch.
Re: ATI super damper with BBC hub [Re: AndyF] #2994906
12/13/21 01:35 PM
12/13/21 01:35 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Same here. My old ATI damper has the Mopar 6 bolt pattern. Wasn't much available for Mopar back then. I made most of my FEAD out of many left over pieces from other Ford and Chevrolet builds laying around and came up with this.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: ATI super damper with BBC hub [Re: 6PKRTSE] #2994910
12/13/21 01:40 PM
12/13/21 01:40 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yep, the "old days". ATI damper with Chevy accessory bolt pattern. Not much made crank trigger and pulley wise for Mopar then. Easier to make brackets for the pickup etc, than to reinvent the wheel.
No reason not to do something to use the most common accessories available now either.
Re: ATI super damper with BBC hub [Re: CMcAllister] #2994947
12/13/21 03:29 PM
12/13/21 03:29 PM
NC
440Jim Offline
440Jim  Offline
NC
Andy, I like that big nut on the end. Should be suitable for turning the engine with a wrench by hand.
Re: ATI super damper with BBC hub [Re: 440Jim] #2994952
12/13/21 03:45 PM
12/13/21 03:45 PM
AndyF Offline
AndyF  Offline
Yes, the spline drive setup from Peterson is strong enough that the engine can be rotated with the large nut. The Chevy style mandrels will break if you try to use the center bolt to rotate the engine.
Re: ATI super damper with BBC hub [Re: AndyF] #2994970
12/13/21 04:37 PM
12/13/21 04:37 PM
NC
440Jim Offline
440Jim  Offline
NC
Yea, it is my understanding that the center bolt on those is just to clamp the pullies/spacers together; not to turn the engine to TDC etc. Especially with spark plugs installed !
Do you think the other aluminum mandrels would be OK to turn the engine by hand if one of the spacers was replaced with a big wrench hex with a keyway to the mandrel center? (or like some pulleys have a set screw with sized end to engage the keyway). For example a 1" dia mandrel with a 1-1/2" hex; or a 1.5" dia mandrel with a 2" hex.
Re: ATI super damper with BBC hub [Re: 440Jim] #2995007
12/13/21 06:06 PM
12/13/21 06:06 PM
AndyF Offline
AndyF  Offline
Maybe, I guess I'd try it and see how it felt. The keyway should be strong enough to withstand the load and so should the 3 bolts for a Chevy pattern or 6 bolts for a Mopar pattern. With spark plugs installed it can take over 100 ft-lbs to rotate the engine, maybe more on a igh compression engine.
Re: ATI super damper with BBC hub [Re: AndyF] #2995339
12/14/21 06:45 PM
12/14/21 06:45 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I made a custom drive for a friends engine. I machined a square drive in to the front, so he could turn the engine over easily. Not sure if I have a pic for it, if I find one I will post it.
Alan Jones
Re: ATI super damper with BBC hub [Re: dakotahotrodder] #2995476
12/15/21 12:53 PM
12/15/21 12:53 PM
Boise
Moparteacher Offline
Boise
I installed a thread insert that dropped the 3/4 diameter thread (minus the locks) down to 9/16 thread. I then used an ARP washer and a a socket head flat screw. The top of the screw sits flush with the washer, which is tapered, and easily cleared the mandrel.
Different brand of dampner and mandrel so your results may vary.
