Race Car Wiring Question
#2994245
12/11/21 12:37 AM
12/11/21 12:37 AM
Posts: 3,017 Sac, CA
mopowers
Sac, CA
For those of you who have wired your cars from scratch, where did you buy all of the singular components (wire, fuse blocks, bus bars, terminals, relays, etc.)? Is there any source to stay away from?
Re: Race Car Wiring Question
[Re: mopowers]
#2994265
12/11/21 08:16 AM
12/11/21 08:16 AM
Posts: 2,969 A shed in England
Tig
A shed in England
After a minor wiring issue / fire in the pits, I ended up using 2 Painless kits. 1 is a stock replacement and the other kit is for the race stuff (W/pump, Fuel Pump, Fans, Ign, data Etc). I upgraded to weather proof connectors where the current would allow and H/D connectors where more current is needed. Most of the extra stuff you mention, I bought off Ebay. I got burned on a couple of items and didn't use them but if you go through a reputable vendor you will be OK. I also switched all the lamps (Bar the headlamps) to LED's and ran an earth loop round the car. It made a big difference, especially on starting. The car has all the stock stuff working and the correct size cables, current capacity and fuses for the "extra's". Race only ? I would just use a race kit with the correct number of circuits (plus a couple of extra's for future), that you need. Edit: I've added a couple of 'phone pics of the boot (Trunk ) area (All I have).
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2994269
12/11/21 08:34 AM
12/11/21 08:34 AM
Posts: 8,068 Tulsa OK
Bad340fish
Tulsa OK
I like the relay and fuse boards from leash electronics. Wire for relay triggers sensors etc (20-22ga) I use wire from my EFI supplier because it is labeled, for any load carrying wire I just use a hodge podge of stuff I bought from a customer who was closing down. For Crimp connectors I use QuickCable, because we are a vendor at work, I like the non insulated stuff then skrink wrap it. For weatherpack and metripack stuff I use ebay, amazon.
If I ever win the lottery I will have a room full of wiring supplies because I never seem to have the right thing lol, that and a wall of nut and bolt hardware lol.
68 Barracuda Formula S 340
[Re: dvw]
#2994288
12/11/21 10:39 AM
12/11/21 10:39 AM
Posts: 289 St.Pete,Florida
lancer493
St.Pete,Florida
A good marine supply store has a lot of quality individual components, wiring and connectors available, due to Coast guard regulations for it's intended environment. This helps if you can build your own systems or redesign or repair. Of course you will probably pay more, but sometimes when you need stuff, being immediately available is a big plus. They generally have more and better materials than the average auto parts stores. No plug and play kits for cars though. Just the ability to see what you are actually getting, vs. choosing from a picture or someone's description. Bill
[Re: lancer493]
#2994326
12/11/21 12:59 PM
12/11/21 12:59 PM
Posts: 19,522 Las Vegas
Al_Alguire
Las Vegas
Individual components we use Waytek or Delcity for wiring, connectors, mega fuses etc. I reallly like the XS Power liteweight battery cable and it has worked well for us. I use Duetch connectors these days on most stuff but have used weather pak in the past. We just rewired our new dragster and used a K&R relay panel and switch panel. Nice stuff for sure. My new project is getting Speedwire like the last couple have. Those are the two we use these days on most stuff. But have used Spaghetti Mendors and Leash products as well for certain thing.
[Re: fbs63]
#2994434
12/11/21 07:19 PM
12/11/21 07:19 PM
Posts: 4,736 On the parachute mount
n20mstr
I have bought a lot off Amazon , BUT read reviews and be careful , some of it is decent , some of it is junk
....BAD A$$ STREET CAR.....
[Re: mopowers]
#2995149
12/14/21 04:46 AM
12/14/21 04:46 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I found Clips and fasteners on Amazon when I just needed 25 count of Packard 56 terminals. I like the quality of the tin plated terminals, and price was not too bad for small order. https://www.clipsandfasteners.com/O-E-M-Terminals-Shells-s/259.htmWaytek wire carries name brand (like 3M) terminal connectors, heat shrink, wire, switches. I mention this because many of the cheap off-shore no name brand terminals are junk. Friend gave me a harbor freight ring terminal kit, and the metal was so thin, you could not get a good crimp on the wire, like trying to crimp tinfoil over a wire. There are a bunch of places to for GXL/TXL wire, like wirebarn.com WireCare.com carries Tefzel wire if your going real high end stuff. The Packard 56 series is what most of the factory connectors are, but they are not sealed from environment. Weather pack connectors are sealed, but bulky, and really don't like being connected and disconnected more than a few times, but they are fairly inexpensive. Metri-pack connectors are more of what newer cars use. Usually smaller sized shells, and pretty easy to connect/disconnect. usually price is good too. Deutsch connectors are premium. The pin/socket terminals are good for multiple connect / disconnect cycles. Connectors (and pin/socket terminals) are more expensive, and the terminals should be crimped with the correct type DMC crimper tool that can cost several hundred dollars. The circular autosport connectors are similar to mil standard 38999 connectors.
[Re: 451Mopar]
#2995173
12/14/21 09:20 AM
12/14/21 09:20 AM
Posts: 4,195 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
The painless kit I bought with relay board had some shortcomings where certain circuits didn't have adequate wire gage. I personally wounldn't use the touchpanel switching some kits utilize. Also weatherpack connectors are lighter gage/lower amp than I care to use. I pieced and patched my vehicle with several differnt sources but then, I had a good wiring guy handy to reference...DVW!
