Remove crank bushing? Finally got it #2994132
12/10/21 05:41 PM
12/10/21 05:41 PM
BDW Offline OP
BDW  Offline OP
I guess this sleeve/bearing? Needs to come out for auto transmission.
Any shade tree methods to get this out?
Update: Watched some YouTube videos of the bread method and reviews were so-so.
Spent $17 on puller from HF and the center sleeve came right out.
I'm guessing I also need to remove the larger bushing?
That doesn't look simple, there's no lip for a puller to grip, it actually feels like the bushing is sitting on a shelf that's larger diameter.
This is turning out harder than I'd expected, what now.
0B53BF3A-495A-4C31-836B-A54E3DCAB128.jpegB5FA47DA-F8AB-4F34-B386-C3E07465CE9C.jpeg88A1E3EC-604A-45EA-8F42-BD9E61558EA1.jpegEF433877-E484-446A-9F15-AB8C94223571.jpeg
Re: How to remove crank sleeve? [Re: BDW] #2994134
12/10/21 05:55 PM
12/10/21 05:55 PM
Kirkland, Washington
Pacnorthcuda Offline
The method of removing a bronze bearing should work on that too….. get a good fitting dowel (I used a stack of washers on a bolt with nut and grinded it down to get the fit) pack cavity with wheel bearing grease, insert dowel, smack with hammer hard,hydraulic force will pop bearing out.
Re: How to remove crank sleeve? [Re: Pacnorthcuda] #2994165
12/10/21 07:45 PM
12/10/21 07:45 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
iagree Yup, a bit messy but as large as that roller pilot is (lots of area) it should pop out easily.
Re: How to remove crank sleeve? [Re: 6PakBee] #2994169
12/10/21 07:51 PM
12/10/21 07:51 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Grease is how I've always done it, but one of the TV car shows the used bread packed in the hole and said it doesn't make the mess grease does. shruggy
Re: How to remove crank sleeve? [Re: Pacnorthcuda] #2994170
12/10/21 07:52 PM
12/10/21 07:52 PM
And if engines can have a nice ass………..that one certainly qualifies!!!
Re: How to remove crank sleeve? [Re: SNK-EYZ] #2994173
12/10/21 07:56 PM
12/10/21 07:56 PM
BDW Offline OP
BDW  Offline OP
Ok, you got my attention, but need some more details, please.
What keeps the grease in? The inner surface of that hole is corrugated, has ridges.
So it would seem the dowel would need to match ridges.
How do I seal the opening so the grease doesn't squirt through?
Thx
Re: How to remove crank sleeve? [Re: BDW] #2994174
12/10/21 08:01 PM
12/10/21 08:01 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If you use heavy grease (or bread) pack it in the center hole and use a tight/snug fitting dowel and hammer the dowel in, it pushes the bearing out.
A little may squeeze out around the dowel, but it shouldn't be that much.
Re: How to remove crank sleeve? [Re: SNK-EYZ] #2994236
12/10/21 10:45 PM
12/10/21 10:45 PM
BDW Offline OP
BDW  Offline OP
Appreciate the info, I'm going to try the dowel and bread method.
I'll report back the results once I get a chance to run to HD for the dowel.
Thx
Re: How to remove crank sleeve? [Re: BDW] #2994255
12/11/21 01:03 AM
12/11/21 01:03 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Use the grease rather than the bread. You won't regret it. As to stopping the grease from squirting out, you can't eliminate it. But you can control it with rags wrapped around the rod (dowel).
Re: How to remove crank sleeve? [Re: 6PakBee] #2994256
12/11/21 01:08 AM
12/11/21 01:08 AM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Safety glasses might be a good idea. work
Re: How to remove crank sleeve? [Re: bobby66] #2994292
12/11/21 10:01 AM
12/11/21 10:01 AM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
If you don't need to save it, weld a bolt to it and a slide hammer.
87 dakota 6.1 hemi
Re: How to remove crank sleeve? [Re: Glen440] #2994537
12/12/21 09:01 AM
12/12/21 09:01 AM
K
Kiddart Offline
Kiddart  Offline
K
The bread theory did not work for me I welded a bolt to it and used slide hammer, 5 minutes later it was out
Thank you
Kiddart
Re: How to remove crank sleeve? [Re: Kiddart] #2994682
12/12/21 04:46 PM
12/12/21 04:46 PM
BDW Offline OP
BDW  Offline OP
Updated first post............the saga continues
Re: How to remove crank sleeve? [Re: BDW] #2995597
12/15/21 05:47 PM
12/15/21 05:47 PM
BDW Offline OP
BDW  Offline OP
Here’s a follow up for anyone dealing with this in the future.
I finally got the larger sleeve out, about 1 hour with a Dremel tool.
Luckily the large spacer is cast iron, but does have a thin steel spacer around outside.
No way hydraulic pressure would have removed this, it sits on a shelf, so no way to build pressure.
So don’t waste effort on the smaller inner bushing.
Unfortunately welding wasn’t an option, but this small project is finally done......
At this rate I’ll have this motor in the car by 2024 frown
E65D513D-25D4-4038-ACFA-1F2AD87D5E02.jpeg01FDFDCE-26AB-453D-A0A1-0D5181AB805E.jpegE4F6844B-5F3B-422F-9DC7-1B193784D155.jpeg
Re: How to remove crank sleeve? [Re: BDW] #2995836
12/16/21 02:19 PM
12/16/21 02:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Wow you really did that the hard way!
I just drill a tiny hole in the center of the edge, then a couple sizes bigger till it is almost the same diameter as the thickness of the ring and a smack on the side with a hammer and punch to shrink the diameter and they fall right out in 5 minutes from the time I start walking to the tool box to grab my tools.
Re: How to remove crank sleeve? [Re: HotRodDave] #2995887
12/16/21 06:12 PM
12/16/21 06:12 PM
BDW Offline OP
BDW  Offline OP
Check in more often, could have used that info a week ago smile
Oh well, it's all a learning experience, hopefully this helps the next guy
Re: How to remove crank sleeve? [Re: BDW] #2996184
12/17/21 03:20 PM
12/17/21 03:20 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
And if you had listened to those recommending the grease method, it'd come out in one piece. You have over a 3:1 area ratio and that puppy would have popped out like a greased pig at the fair.
Re: How to remove crank sleeve? [Re: 6PakBee] #2996236
12/17/21 06:55 PM
12/17/21 06:55 PM
BDW Offline OP
BDW  Offline OP
Sorry, that’s not true, if you look at 2nd pic you’ll see the bushing sits on a shelf the same exact diameter.
Nothing for the grease to push on, welding a nut or cutting out is only option.
Re: How to remove crank sleeve? [Re: BDW] #2996348
12/18/21 09:17 AM
12/18/21 09:17 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm just going to say one more thing and then I'll shut up. Did you try grease? If not then you do not know that it wouldn't have worked.
Re: How to remove crank sleeve? [Re: 6PakBee] #3001036
01/02/22 08:48 AM
01/02/22 08:48 AM
Groton, MA
N
nebo Offline
nebo  Offline
N
Groton, MA
I tried the grease method on my Gen 3 hemi and it did not work, had to grind it out with a dremel tool.
