Differential Yoke- 7290 #2992599
12/06/21 03:47 PM
12/06/21 03:47 PM
SE Wisconsin, USA
RP's R/T's Offline OP
SE Wisconsin, USA
I need to replace the Yoke to a 7290 10-spline on an 8 3/4.
I was going to just buy a new one, but prices are all over...for what i would think would be a fairly common design.
Seems anywhere from about $70 to $150.
So, why the price swing? (other than some companies are just more expensive..spare me the obvious)
Re: Differential Yoke- 7290 [Re: RP's R/T's] #2992601
12/06/21 03:58 PM
12/06/21 03:58 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
There maybe three grades? Stock, Forged, Billet?
Re: Differential Yoke- 7290 [Re: Cuda340] #2992615
12/06/21 04:55 PM
12/06/21 04:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I'd like to "spare you the obvious" but most all of them are the same yoke from the same foundry from what I've seen. Mancini has the middle of the road price at I think $135 shruggy Other suppliers sell the same yoke for more and some for less.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Differential Yoke- 7290 [Re: RP's R/T's] #2992778
12/07/21 12:37 AM
12/07/21 12:37 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
you said replace the yoke TO a 7290 .
soooo do you now have a 7260 ?
if so just get the u joint that is 7260 x 7290 and save some money and time .
several brands have them !
Re: Differential Yoke- 7290 [Re: Cuda340] #2993216
12/08/21 01:31 PM
12/08/21 01:31 PM
Locomotion Online content
Locomotion  Online Content
I was under the same impression. I went to a 7260 billet yoke with u-bolts and solid Spicer joints after an OEM yoke "spread" & broke. Never a problem since then.
Re: Differential Yoke- 7290 [Re: Locomotion] #2993568
12/09/21 12:19 PM
12/09/21 12:19 PM
moparx Offline
moparx  Offline
some have good luck using the 7260 joint/yoke combo, while others go to the big guy 1350 size.
any idea where the sizes fit in with hp/tq in say, the average B body ? assuming a good yoke and solid joint ?
beer
Re: Differential Yoke- 7290 [Re: moparx] #2993591
12/09/21 01:10 PM
12/09/21 01:10 PM
beer
Difficult to say because there's a lot more to it - weight, traction, torque, stick/auto, etc. Same situation with how well an 8 3/4 will hold up. (ring & pinion and caps). A heavier, dead-hooking, higher HP/torque combo will eventually find the weak link in the "chain" - output shaft, slip spline yoke, u-joints, driveshaft tube, rear end yoke, gears, caps, axles, wheel studs. My Dart at 3,540 + lbs pulls the wheels every run. Early on I found out the hard way that an OEM yoke can eventually spread, gets hammered from the movements & breaks, or just plain fatigue.
Re: Differential Yoke- 7290 [Re: Locomotion] #2993620
12/09/21 02:17 PM
12/09/21 02:17 PM
moparx Offline
moparx  Offline
very true on all aspects you point out.
i guess a guy has to stand by this old, famous quote : "Do you feel lucky...........Punk ?" whistling biggrin
beer
Re: Differential Yoke- 7290 [Re: RP's R/T's] #2993655
12/09/21 03:48 PM
12/09/21 03:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You did not mention the issue with the one you have, so...... just in case;
If it is good other that the machined surface the seal rides on, redi-sleeves are available, easy repair.
