DLC coatings, possible uses? #2992676
12/06/21 08:17 PM
12/06/21 08:17 PM
gregsdart Offline OP
DLC coatings are showing up on more and more parts. I just bought a set of piston pins DLC coated. Now there is a post about lifters. Could DLC find its' way onto piston skirts, crank journals, rocker shafts,. Other than cost , what limits it's use?
One area that I would love to see it is in rocker arm shafts. A DLC coated shaft in my Jesel paired rockers and a bronze bushing, with a large hole in the top of the rocker body for splash oiling. Even with limited oiling it might work well in a drag application. One less set of needle bearings to end up in the oil pump!!
Re: DLC coatings, possible uses? [Re: gregsdart] #2992680
12/06/21 08:37 PM
12/06/21 08:37 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
From what I read it can be used on any metal
Re: DLC coatings, possible uses? [Re: gregsdart] #2992685
12/06/21 09:01 PM
12/06/21 09:01 PM
AndyF Offline
AndyF  Offline
You need to talk to NASCAR guys rather than drag racers. NASCAR guys coat the wheel bearings and all sorts of stuff like that. Basically anything that has sliding or rolling friction gets some sort of coating including gears, bearings, shafts, etc.
Re: DLC coatings, possible uses? [Re: AndyF] #2992724
12/06/21 10:22 PM
12/06/21 10:22 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Leno used DLC on the cam followers in his Pontiac Firebird Sprint with OHC six.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: DLC coatings, possible uses? [Re: DynoDave] #2992879
12/07/21 01:48 PM
12/07/21 01:48 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The intake valves on my -1 motor project are CrN coated which is another slick coating. It is very hard although it is abradable.
http://delwestengineering.com/specialized-coatings/
Re: DLC coatings, possible uses? [Re: gregsdart] #2992996
12/07/21 07:05 PM
12/07/21 07:05 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The base material needs to be hard and possess very good compressive strength. Base materials like aluminium, titanium and some steels wouldn't be suitable.
Jesel offers the DLC coating on their Hemi rocker shafts for Top Fuel from memory, or at least they used to.
Alan Jones
Re: DLC coatings, possible uses? [Re: LA360] #2993002
12/07/21 07:22 PM
12/07/21 07:22 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is that the same as this stuff?
http://www.microblueracing.com/
Kevin
Re: DLC coatings, possible uses? [Re: Twostick] #2993055
12/07/21 09:59 PM
12/07/21 09:59 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Kevin
That looks like some amazing stuff for gears and roller bearing cups to reduce heat generated by friction up
Gus beer
64 Plymouth Savoy
Dana 60
Re: DLC coatings, possible uses? [Re: fourgearsavoy] #2993064
12/07/21 10:17 PM
12/07/21 10:17 PM
Rittman Ohio
Rittman Ohio
I looked this coating up and I see where some companies coat cutting tools with it to reduce heat and wear. Also lots of firearm parts can be coated too like barrel slides and bushings on the actions. I can see a possible opportunity to retirement income work
Gus beer
64 Plymouth Savoy
Dana 60
Re: DLC coatings, possible uses? [Re: Twostick] #2993100
12/08/21 02:15 AM
12/08/21 02:15 AM
LA360 Offline
LA360  Offline
Kevin
Different stuff best I can tell, DLC is applied with plasma-assisted chemical vapor deposition from what I have read. A lot of cutting tool coatings are done in the same way.
https://www.sciencedirect.com/topics/materials-science/diamond-like-carbon-coating
They seem to be able to put that Micro Blue stuff on anything
Alan Jones
Re: DLC coatings, possible uses? [Re: LA360] #2993432
12/09/21 12:45 AM
12/09/21 12:45 AM
LA360 Offline
LA360  Offline
https://www.enginelabs.com/engine-tech/engine/piston-coatings-when-you-should-and-shouldnt-use-them/
Some light reading, DLC is mentioned around mid way through the article
Alan Jones
