2892513 aluminum BB belhousing #2992125
12/04/21 11:20 PM
12/04/21 11:20 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I have two of these belhousings. One of them has an additional bolt boss welded on, see pics.
What do you suppose this was for ?
Maybe for a BB 4-speed deal in an A-body ? I don't know. Maybe something totally different ?
I thought the -513 bells were B and E body bells.
Re: 2892513 aluminum BB belhousing [Re: hemienvy] #2992136
12/05/21 12:01 AM
12/05/21 12:01 AM
I have a 1969 Dart GTS H code 4 speed car that I took in trade years ago minus the motor, trans and bell housing, flywheel and clutch linkage.
I ended up using a 1965 cast iron stock Mopar bell for the 383 and 361 B motors to use the 10.5 inch flywheel, clutch and replica clutch linkage in it to drive it on the street, it works and fits well: up:
Re: 2892513 aluminum BB belhousing [Re: Cab_Burge] #2992152
12/05/21 07:29 AM
12/05/21 07:29 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Check the date code. That may help. I bet the blue one is cast much later.
Re: 2892513 aluminum BB belhousing [Re: fastmark] #2992287
12/05/21 03:04 PM
12/05/21 03:04 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I can't read the date codes, but the extra boss is welded on, not cast in.
Re: 2892513 aluminum BB belhousing [Re: hemienvy] #2992299
12/05/21 03:48 PM
12/05/21 03:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Welded in = modified.
Re: 2892513 aluminum BB belhousing [Re: Alaskan_TA] #2992300
12/05/21 03:51 PM
12/05/21 03:51 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
iagree
Re: 2892513 aluminum BB belhousing [Re: 6PakBee] #2992307
12/05/21 04:12 PM
12/05/21 04:12 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
OK.
Of course it's modified.
My question is: Does this modification look like it might facilitate something obvious, for example, use in an A-body instead of an E-body ? Use of a particular bracket ? Someone added it for a reason, what might that reason be ?
Of course it could be just a one-off non-predictable modification.
Re: 2892513 aluminum BB belhousing [Re: hemienvy] #2992319
12/05/21 04:50 PM
12/05/21 04:50 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No need for the boss in an A-Body application, no idea why it is there...
shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: 2892513 aluminum BB belhousing [Re: hemienvy] #2992334
12/05/21 05:29 PM
12/05/21 05:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The lower welded-on boss could be for a hydraulic slave cylinder.
