Page 1 of 3 1 2 3
FIRE Pit in back yard #2991805
12/03/21 08:49 PM
12/03/21 08:49 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
What do you think is a fair distance from neighbor's house and or garage from your fire pit to be a good neighbor?
distance in feet
single choice
Votes accepted starting: 12/03/21 08:48 PM
You must vote before you can view the results of this poll.
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: FIRE Pit in back yard [Re: bigdad] #2991817
12/03/21 09:08 PM
12/03/21 09:08 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The distance in feet does not come into play as long as conditions are safe for a fire.
That said, any issues?
Warm weather, neighbors with open windows?
Neighbor with respiratory issues?
Etc., etc.
Too many variables..........
If it has become an issue, talk to your neighbors.
Re: FIRE Pit in back yard [Re: bigdad] #2991819
12/03/21 09:22 PM
12/03/21 09:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Code around here mandates that a fire pit, bbq, etc be a minimum of 10 feet from the nearest building. That's for safety, being considerate is another thing.
Me, I don't care it's the same as a chimney on a fireplace from my point of view.
Re: FIRE Pit in back yard [Re: Sniper] #2991822
12/03/21 09:31 PM
12/03/21 09:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think that the number of people that would be gathered around it would also be a factor.
Re: FIRE Pit in back yard [Re: stumpy] #2991824
12/03/21 09:34 PM
12/03/21 09:34 PM
Kirkland, Washington
Pacnorthcuda Offline
I don’t.
Re: FIRE Pit in back yard [Re: Pacnorthcuda] #2991825
12/03/21 09:44 PM
12/03/21 09:44 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I don't think everyone's backyard needs to be a campground if you live in town .. a nice small quiet evening fire maybe 30 inches around is one thing but, a roaring fire 10 foot in diameter less than ten feet from someone's buildings is a bit much .
Not to mention, noisy generator running to power up the camper parked in the driveway as well
Re: FIRE Pit in back yard [Re: bigdad] #2991826
12/03/21 09:48 PM
12/03/21 09:48 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
it is dry here normally we have a few inches of snow on the ground, lots of leaves .. fire would start easy, they go in leave it unattended at night, still roaring ..pretty selfish I think
Re: FIRE Pit in back yard [Re: bigdad] #2991829
12/03/21 09:55 PM
12/03/21 09:55 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
there is more to this story?
Re: FIRE Pit in back yard [Re: Sniper] #2991859
12/03/21 11:19 PM
12/03/21 11:19 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
More like .. ?
Pretty simple, would you in town build a fire pit near your neighbor's structures ..?
No more to it than that
Re: FIRE Pit in back yard [Re: bigdad] #2991861
12/03/21 11:32 PM
12/03/21 11:32 PM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
How big are the lots in your area? Ours are 1 acre. Mine is roughly 175' x 275'ish. My firepit lives in the center of the backyard...I use common sense when burning and have no issues with the neighbors......they all have pits as well.
Re: FIRE Pit in back yard [Re: bigdad] #2991923
12/04/21 09:45 AM
12/04/21 09:45 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
More like .. ?
You sure as heck implied there is more to the story.
But no I would not build a fire pit near my neighbor's structures, in town or otherwise. But then again I don't have a postage sized lot that you can spit out your window and hit your neighbor's house either. IOW, there is nowhere on my lot I could build a fire pit and be within 10ft, or less, of my neighbor's structures even if I wanted to. Setbacks are a thing around here.
Fire codes are pretty universal and a 10 ft minimum clearance between a fire pit and a structure is a minimum. Call the Fire Marshal.
Re: FIRE Pit in back yard [Re: Sniper] #2991938
12/04/21 10:44 AM
12/04/21 10:44 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I'm designing one for my back yard, but the issue I am most concerned with, and not yet mentioned, is overhead and nearby trees.
Any falling debris/limbs, etc could cause things to go sideways fairly quickly. My current design will be in a sunken circular pit with seating surrounding a center fountain.
It will be propane fueled fire pit, as its strictly for cosmetics.
Re: FIRE Pit in back yard [Re: Sniper] #2991940
12/04/21 10:46 AM
12/04/21 10:46 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
My Garage is the left .. my wall is pictured, the property line is right at the edge of the trees .. you can see their fire pit , all those parts of a tree are on my property .
Re: FIRE Pit in back yard [Re: bigdad] #2991942
12/04/21 10:48 AM
12/04/21 10:48 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
the fire pit is 18 feet from my property , the neighbor just can't understand why I ask her not to start fires and then go to bed
Re: FIRE Pit in back yard [Re: bigdad] #2991947
12/04/21 11:02 AM
12/04/21 11:02 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
A normal fire I wouldn't have an issue with, a bonfire yes.
An unattended fire is probably a violation of code too and unacceptable regardless.
Re: FIRE Pit in back yard [Re: bigdad] #2991949
12/04/21 11:10 AM
12/04/21 11:10 AM
St. Louis, Missouri area
Cometstorm Offline
"Beat It"
Cometstorm  Offline
"Beat It"
We get a lot of enjoyment out of ours.
Great to cop some drinks, and watch satellites pass over, or planes initiating their landing approach to St. Louis International Airport (we are about 20 miles from the runways). up
Re: FIRE Pit in back yard [Re: bigdad] #2991951
12/04/21 11:35 AM
12/04/21 11:35 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Walk into your local fire department and ask them. I'll (almost) guarantee you that your town/county have ordinances that cover size, location, etc...of fire pits.
Re: FIRE Pit in back yard [Re: Cometstorm] #2991963
12/04/21 12:22 PM
12/04/21 12:22 PM
moparx Offline
moparx  Offline
Comet, i really like your waterfall garden pool ! up
any fish in it ?
beer
Re: FIRE Pit in back yard [Re: moparx] #2991966
12/04/21 12:36 PM
12/04/21 12:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Looks like a Koi in Comet's pond.
From what I can tell, the firepit in Bigdad's photo looks too close to his garage & trees, and a rather inconsiderate or rude thing to do.
Looks to be sized for a bonfire as well, not exactly brilliant near trees.
And if the neighbor doesn't understand unattended fires, I'd be concerned; that's a bad combination.
Agree that the local Fire Dept may have an opinion and require a change of location.
Re: FIRE Pit in back yard [Re: topside] #2991973
12/04/21 12:58 PM
12/04/21 12:58 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Why a fire pit? If you want heat get one of these.
Page 1 of 3 1 2 3
