Front Drum/Hub Studs #2991590
12/03/21 11:54 AM
12/03/21 11:54 AM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
After removing the original studs to separate a bad hub
I can not find new studs that will hold it all back in place?
Does any one know of a supplier for these type of studs?
Also left's and right's if possible.
Thanks! John
Re: Front Drum/Hub Studs [Re: moparjohn] #2991632
12/03/21 01:15 PM
12/03/21 01:15 PM
moparx Offline
moparx  Offline
the new studs have to be swedged to the hub in order to hold it in place.
there is a tool to do that, but i don't have picture or a link.
think of a swedge like this. the exposed spline area of the stud after the drum is in place is flattened/peined over, capturing a small area of the drum around the stud holes with the stud.
beer
Re: Front Drum/Hub Studs [Re: moparjohn] #2991640
12/03/21 01:32 PM
12/03/21 01:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some believe that swaging is unnecessary. If your drum indexes off the hub snuggly, then swaging is not needed since the tightened wheel will keep the drum in place like the rear drums. If the fit on the hub isn't snug you risk having an out-of-round drum installation; in this case, swaging locks the drum to the hub.
If swaging is necessary the drum has to be turned after swaging to ensure roundness.
Re: Front Drum/Hub Studs [Re: moparx] #2991642
12/03/21 01:34 PM
12/03/21 01:34 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
John - Sent you an email.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
