Re: Challenger 1320 in my future
[Re: Brad_Haak]
#2992191
12/05/21 10:55 AM
12/05/21 10:55 AM
Posts: 2,858 Pattison Texas
CSK
Pattison Texas
Well, here's a bit of a p!sser: found out yesterday that the rear seat option isn't available currently for 2022. I'm back to looking through what's left of the 2021s, or possibly a nice used one. Are you saying that you can't get a 2022 1320 WITH a rear seat ?
[Re: CSK]
#2992214
12/05/21 12:07 PM
12/05/21 12:07 PM
Posts: 1,126 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Well, here's a bit of a p!sser: found out yesterday that the rear seat option isn't available currently for 2022. I'm back to looking through what's left of the 2021s, or possibly a nice used one. Are you saying that you can't get a 2022 1320 WITH a rear seat ? Here's the e-mail discussion w/ the rep, after I noticed the build sheet did not include the rear seat option as specified: Me: Unless something has changed for 2022 that I'm unaware, the rear seat option can be added as an override of the standard 1320. I've attached the sticker from one of the 2021 cars I found locally, but didn't want because it's Pitch Black. It retains the standard cloth interior, but has both passenger seat and rear seat options (see red oval in lower left corner). It's definitely possible, although confusing. Even the online "Build Your Car" feature doesn't disable the Rear Seat Delete selection when the Rear Seat Option - Cloth option is selected. The other way is the 1320 Plus package, which is primarily an interior upgrade that includes both front passenger seat & rear seat along w/ leather upgrade. We're not interested in that option. Rep: Yes that has indeed changed from last year. Once you select the 1320 package, the Rear Seat Cloth options is not available to select. It is not available in the 1320 plus package either. Once you select the 1320 package, it does not allow the Rear Seat Option as an available option. So if that is an important option, I will put you on a waiting list and if/when it is available, I can let you know and proceed with the build from there.Me: Yeah, one of the reasons we decided to simply order a 2022 because half of the 2021s we've found weren't ordered w/ the rear seat. Just to be clear, if we add the 1320 Plus Group for 2022, will that include the rear seat is it does for 2021? If so, we'll go w/ the 1320 Plus Group. Rep: No, the 1320 Plus Group does not give you the rear seat.
This is everything in the 1320 Plus Group. Power Tilt/Telescope Steering Column (SUB) Door Trim Panel w/Ambient Lighting (CBR) Nappa/Alcantara Performance Seats (*SL) Heated Steering Wheel (NHS) Black-Edged Premium Floormats (CCJ) Premium-stitched Dash Panel (JAD) Ventilated Front Seats (CAJ) Radio/Driver Seat/Mirrors Memory (LEW)
Once you get the 1320 package, you can not get the Cloth Back Seat. Maybe it will change later in the year, but currently you can not get the Cloth Back Seat with the 1320. --------------------------------------------------------------------------------------------------------- This guy does special orders on a regular basis so I'm 99% sure he's got his facts straight... even though it makes no sense to me. EDIT: I just posted a question on the General Discussion forum asking if anyone who works at a dealership can confirm this.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#2992227
12/05/21 12:32 PM
12/05/21 12:32 PM
CSK
Pattison Texas
Once you get the 1320 package, you can not get the Cloth Back Seat. Maybe it will change later in the year, but currently you can not get the Cloth Back Seat with the 1320. --------------------------------------------------------------------------------------------------------- This guy does special orders on a regular basis so I'm 99% sure he's got his facts straight... even though it makes no sense to me. EDIT: I just posted a question on the General Discussion forum asking if anyone who works at a dealership can confirm this. Well that is not very smart on their part, thanks for posting
[Re: DoubleD]
#2992349
12/05/21 06:15 PM
12/05/21 06:15 PM
Posts: 1,550 Michigan
Kiddart
do you want the rear seat or do you want rear seat delete?
If you want rear seat delete,,, when you order your car, go to service or parts counter and order the Mopar rear seat delete and it will be in when the car comes in.
Thank you Kiddart
[Re: Kiddart]
#2992387
12/05/21 08:45 PM
12/05/21 08:45 PM
Brad_Haak
Loudoun County, VA
Definitely want the rear seat installed for putting a couple of extra people in the car for normal use. I want a Challenger, not a Viper.
[Re: Brad_Haak]
#2992483
12/06/21 09:51 AM
12/06/21 09:51 AM
Kiddart
Ahh I get it. The rear seat is almost unusable. it gets really small back there.
Good luck in your findings. and you will love the car its different from a regular scat pack its hard to explain but it is different
Thank you Kiddart
[Re: Kiddart]
#2993913
12/10/21 01:37 AM
12/10/21 01:37 AM
Brad_Haak
Loudoun County, VA
Target acquired: 2021 Sinamon Stick w/ the must-have rear seat. Here it is on the dealer lot before I drove it 120 miles back home tonight.
[Re: CSK]
#2993967
12/10/21 10:17 AM
12/10/21 10:17 AM
Kiddart
Nice looking color!!! that was my second choice. wait untill you get 500 miles on it and everything unlocks, that's when the fun begins!!
enjoy your new ride
Thank you Kiddart
[Re: Kiddart]
#2994004
12/10/21 12:21 PM
12/10/21 12:21 PM
Brad_Haak
Loudoun County, VA
... wait untill you get 500 miles on it and everything unlocks, that's when the fun begins!!
I have no idea what you're talking about ... There are a bunch of things I need to learn about this car, but whatever you're referring to wasn't even on my radar.
[Re: Brad_Haak]
#2994535
12/12/21 09:58 AM
12/12/21 09:58 AM
Kiddart
all the race features unlock at 500 miles. trans brake and all the data logging all unlocks, at least that is what my 2020 did. none of the race features worked until i hit 500 miles.
My sales guy told me it was a break in period??
Sorry I should have been more clear.
Thank you Kiddart
