Tranzact of Indy Valvebody Issue #2926909
05/26/21 01:14 PM
05/26/21 01:14 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Does anyone know if Tranzact of Indy is still open?
I have what I suspect is a valvebody issue that I was hoping I might get some tech help with.
Very strange... but when you fire the car up and put it into gear, it just rev's like it's in neutral. Then if you hold it at 2,000 RPM or so for say 5 seconds it will start to move. It almost feels like you're letting the clutch out.
I took the trans apart yesterday and everything looks FLAWLESS inside. Not one hint of any gear slipping anywhere.
I can send the converter back to be looked at too, but thought I'd start with the valvebody.
Re: Tranzact of Indy Valvebody Issue [Re: dizuster] #2926923
05/26/21 01:30 PM
05/26/21 01:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Are you starting the engine with the shifter in Park or Neutral?
Re: Tranzact of Indy Valvebody Issue [Re: John_Kunkel] #2926930
05/26/21 01:37 PM
05/26/21 01:37 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Both... lol It's a pushbutton.
I should note a couple more things also.
1) It never did this before. This is a new issue that shown up in the last year or so.
2) The last time the car was raced was 2 years ago, and ran 6.22 in great air with a 1.37 60ft. This past weekend, the car went 6.30, but with only a 1.51 60ft. Still had great MPH though, which made me thing the stator might be broken. But PTC told me it should be a spragless converter, so I'm waiting for a call back from them to confirm based on the serial number I have now.
Not sure how that might effect this issue where it feels like it is slipping after start up.
Re: Tranzact of Indy Valvebody Issue [Re: dizuster] #2926975
05/26/21 02:55 PM
05/26/21 02:55 PM
Check both band adjustments twocents
Take a hard look at the front drum also scope
Re: Tranzact of Indy Valvebody Issue [Re: Cab_Burge] #2926978
05/26/21 03:00 PM
05/26/21 03:00 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Good advice Cab. I did that already... both are good, and there isn't a sign of hot spot anywhere on the drums, bands, steels, or clutches.
I talked to PTC. They think it is probably a hung Torque Converter Control Valve in the valve body. I'll get that apart next and start looking at it.
The other symptom that I talked to PTC about, was that on the 2nd pass, the shift light came on right away off the transbrake release. They said that's a symptom of the converter not being full also.
Re: Tranzact of Indy Valvebody Issue [Re: dizuster] #2926997
05/26/21 04:07 PM
05/26/21 04:07 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Should’ve checked line pressure first, that would pointed u in the right direction. 2cts.
Re: Tranzact of Indy Valvebody Issue [Re: dizuster] #2927016
05/26/21 05:15 PM
05/26/21 05:15 PM
A727Tflite Offline
A727Tflite  Offline
With those symptoms the first thing to do is see where the fluid level is before starting it.
If very high, above your full/hot mark, then start the engine and once you get a good engagement check the fluid again.
If lower, then the converter drained down.
Two things usually cause that. A stuck/sticky TCCV or excessive pump rotor face clearance. If a recent occurrence for you then likely not the pump clearance.
Age old issue.
Re: Tranzact of Indy Valvebody Issue [Re: A727Tflite] #2927062
05/26/21 07:49 PM
05/26/21 07:49 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Age old issue.
I had a sb pushbutton that did this if it sat for more than a few hours. Was told it was common . Just converter draining back
Re: Tranzact of Indy Valvebody Issue [Re: Wirenut] #2927066
05/26/21 08:20 PM
05/26/21 08:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
This isnt normal converter drain back. When he pulls away in the pits it sounds like its leaving in high gear. And that's after it's been running a while. Not saying the converters full. That could be the issue. But its run plenty long enough for a normal fill.
Doug
Re: Tranzact of Indy Valvebody Issue [Re: dvw] #2927068
05/26/21 08:39 PM
05/26/21 08:39 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
There was a TSB, for the reaction shaft turning in the support. One of the symptoms was no forward engagement, due to misalignment of the feed holes. If you can compare the reaction shaft support to another, just to rule it out. I remember that fully blocked feed holes would slip the rear clutch dramatically. Doesn’t sound like you’re seeing it, though.
Re: Tranzact of Indy Valvebody Issue [Re: Leigh] #2927083
05/26/21 09:42 PM
05/26/21 09:42 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I can't help but this is why I stay here.
Good to see IDEAS THAT CAN HELP
Re: Tranzact of Indy Valvebody Issue [Re: rickraw] #2927176
05/27/21 09:00 AM
05/27/21 09:00 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
That was the FIRST thing I said to DVW when I called him after I took it apart and didn't find any issues!!!!
Thanks to all of those who've given ideas. We have family plans this weekend, but I'll report back next week after some further investigation!
Re: Tranzact of Indy Valvebody Issue [Re: dizuster] #2927238
05/27/21 01:13 PM
05/27/21 01:13 PM
A727Tflite Offline
A727Tflite  Offline
Line pressure is unaffected by converter fill. Doug said it moved under it’s own power and you said no burnt clutches.
Low line would have wounded clutches.
Look at the valve body - corner by the spring retainer bracket. There is a small long skinny spring next to the reg valve.
That’s the TCCV and spring. That’s your likely culprit. That valve should be all the way in it’s bore. And it should fall out once that bracket is removed.
Re: Tranzact of Indy Valvebody Issue [Re: FastmOp] #2927246
05/27/21 01:30 PM
05/27/21 01:30 PM
moparx Offline
moparx  Offline
you bet ! up bow
and as an added benefit, these guys "remind" us that are a "tad" older, [as in ME] stuff we have forgotten. biggrin
beer
Re: Tranzact of Indy Valvebody Issue [Re: moparx] #2927327
05/27/21 04:33 PM
05/27/21 04:33 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Transman for the win... TCCV was stuck (I had to bang the side of the valve body a bunch of times to get it to finally come out).
Not sure why, but it is very corroded!!! I'll get it cleaned up and put back together. Thanks for the help Lou!
Re: Tranzact of Indy Valvebody Issue [Re: dizuster] #2990788
12/01/21 09:55 AM
12/01/21 09:55 AM
USA
CCG Offline
CCG  Offline
USA
Hello Moparts forum.
I wish I did not have to post this. However, Tranzact of Indy, Race Parts Wholesale Indianapolis, Joe Chrisman is not responding to any of my messages after I sent him a deposit for one of his Ultraflite transmissions on May 10th, 2021. We spoke on the phone several times, however over the last four months he will not answer the phone at (317) 846-4933, emails to tranzactracing@aol.com, or certified letters sent to his address 503 North Arthur Drive, Indianapolis, IN 46280. Does someone know how to contact him? I hope he is not trying to keep this money without doing his job. I also do not want anyone in this community to have this happen.
Thanks for any help!I
Re: Tranzact of Indy Valvebody Issue [Re: CCG] #2990798
12/01/21 10:20 AM
12/01/21 10:20 AM
tboomer Online work
tboomer  Online Work
You have at least 25 posts on this subject. You should be contacting the Better Business Bureau,your credit card company or filing a claim in small claims court. Good luck as I hate to see somebody ripped off on race parts.
Re: Tranzact of Indy Valvebody Issue [Re: tboomer] #2991014
12/01/21 08:50 PM
12/01/21 08:50 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’m just surprised that nobody seems to know anything about him?
Re: Tranzact of Indy Valvebody Issue [Re: J_BODY] #2991085
12/01/21 10:57 PM
12/01/21 10:57 PM
A727Tflite Offline
A727Tflite  Offline
Maybe call TCI and see if they are back ordered on the Brake he makes for them.
If so maybe he is out of commission.
Re: Tranzact of Indy Valvebody Issue [Re: A727Tflite] #2991100
12/01/21 11:56 PM
12/01/21 11:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That doesn’t excuse him from not picking up the phone
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
