Re: Post your W headed small blocks
[Re: RAY1969CARS]
#2990278
11/29/21 08:47 PM
11/29/21 08:47 PM
Posts: 1,559 New Smyrna Beach FL
scottb
New Smyrna Beach FL
My old 420 cubic inch W9 motor heads were ported by modern cylinder heads heads flowed 387@750 14.5 compression 280-288 roller with 430-440 lobe Jesel rockers 1.8 intake 1.85 exhaust 420 intake ported by Ryan apd 1150 carb ran a best of 9.33 @147 with a lazy 1.42 60 ft motor differently had a 8 sec pass in it sold everything and bought a R5 P7 motor
[Re: scottb]
#2990282
11/29/21 09:05 PM
11/29/21 09:05 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
[Re: MR_P_BODY]
#2990396
11/30/21 09:16 AM
11/30/21 09:16 AM
Posts: 4,987 new jersey usa
11secdart
new jersey usa
My current 367 ... 40 over 360 Magnum block, W2 heads, 10-1 compression, Bullet cam, 249/256 , 584/595 , Victor W2 intake, 750 HP carb... has gone best of 11.09 so far only been out a few times motor going on a dyno soon for additional tuning. I have had these heads on a few different combos .. 340s and 360s ... best they ran on a 340 was 10.70s with 12 to 1 compression made 527 hp with a roller cam... with the 360 and a 590 lift mech. cam at 549 hp / 450 tq. it went 10.40 a best in my 3,150 lb Dart. I took that combo and lowered the compression for pump gas with a proper tune I am sure it will run 10.90s I run on a throttle stop to run 11.50s for index and Sportsman class racing but still want a strong combo capable of low 11s. I also have a 408... R3 block with Indy 360-1 heads that has been troublesome especially with the Indy rockers my original plan was to use W2 heads I wish I would have!
[Re: scottb]
#2990637
11/30/21 08:44 PM
11/30/21 08:44 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
[Re: RAY1969CARS]
#2990666
11/30/21 10:00 PM
11/30/21 10:00 PM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#2990668
11/30/21 10:01 PM
11/30/21 10:01 PM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#2990669
11/30/21 10:03 PM
11/30/21 10:03 PM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#2990770
12/01/21 09:00 AM
12/01/21 09:00 AM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
1971 340 block, 3.46'' stroke, 4.080'' bore, 11.4 compression, 264/268 @ .050 Hughes SFT, victor W2 intake, 810 W2 heads that flow 286 cfm @ 650, 1-5/8'' truck LA headers, drinks methanol.
[Re: 79410aspenrt]
#2990778
12/01/21 09:21 AM
12/01/21 09:21 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Cripes, they is small block PORN! Loving them late model heads...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
