FGT 360 magnum dragpak oil pan for Dart sport/duster #2990611
11/30/21 07:17 PM
11/30/21 07:17 PM
Massachusetts
E
ericlre79 Offline OP
E
Massachusetts
The ex-whinery-ex paznack ex-dye dart sport is finally getting converted into a FGT superstocker.
Issue: The stock dragpak oil pan and the miloden spare from my dakota will not fit due to the idler arm.
Truck is rear sump, does 100 footers and is fine with 6 quarts, this car is getting the same drivetrain, will just be a bit lighter.
What is everyone using for small block oil pans for racing with the stock idler arm for the Abodys?
Eric
Re: FGT 360 magnum dragpak oil pan for Dart sport/duster [Re: ericlre79] #2990632
11/30/21 08:36 PM
11/30/21 08:36 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Kevko should have something that will make you happy.
https://kevkoracing.com/collections/mopar-oil-pans-1
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: FGT 360 magnum dragpak oil pan for Dart sport/duster [Re: Michael Ecks] #2993738
12/09/21 06:45 PM
12/09/21 06:45 PM
Massachusetts
E
E
Massachusetts
Thanks found a custom race proven one.
Eric
Re: FGT 360 magnum dragpak oil pan for Dart sport/duster [Re: ericlre79] #2993799
12/09/21 08:38 PM
12/09/21 08:38 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Rear sump Magnum (360) on the 340, engine mounts on the frontside of block ears, a little bending of that link. If you have the one year only 318 Dak Shelby pan you’re also good to go (try finding one of those lol)
