Re: Need some 4speed help
[Re: 8urvette]
#2989949
11/28/21 07:17 PM
11/28/21 07:17 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Okay, if i need to replace parts... WOuld i be able to save the cost of replacing the gears by going with a faceplated gear from liberty? Do they just remove the synchro teeth and weld on their part? What about the sliders? Is theirs a custom made one or is it machined from a stock unit? You don't need any gears just get a rebuild kit with new brass and you should be good to go for about $200 . Face-Plate from Liberty's would run you about $75 per gear and I think the sliders would run about $125-$150 each and get ready to wait 2-6 months to get your gears back. Here's pic of my face-plated Richmond race box Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Moparteacher]
#2989993
11/28/21 10:11 PM
11/28/21 10:11 PM
Posts: 782 wine country
8urvette
wine country
Since I have your attention here are a few more pics of the sliders and the gears. What do you think?? Since I have been looking at new pieces online i am seeing how much wear is on these parts. Just would like someone else to chime in on them as well.
My thought is to replace the sliders, synchros and leave the gears.
[Re: 8urvette]
#2990334
11/29/21 11:10 PM
11/29/21 11:10 PM
Posts: 610 Boise
Moparteacher
Boise
540ci is a lot for any a833, even an 18 spline.
Maybe their concern was more about the choice of trans and less about the modifications.
With the torque a 540 produces it's likely 3rd gear is going to be nonexistent given enough traction. You'll shear the teeth off 3rd gear speed gear and cluster gear before you break the modified parts.
A $1000. quote sounds like it includes disassembly and reassembly. The website quotes $120 per gear (3x$120=$360) to faceplace or Pro Ring and then the cost of two modified sliders. I would expect $600-$700 without the additional labor to build. Some options: Jerico 4 or 5 speed, G-force 4 or 5 speed (I have a Long H-pattern shifter for the 4-speed for sale), Tremec TKX, Liberty Extreme-T, Passon, or maybe something from a Vipor T-56 with upgrades, etc.
[Re: lancer493]
#2990371
11/30/21 02:18 AM
11/30/21 02:18 AM
Posts: 9,102 Rogue River, OR
Jeremiah
Rogue River, OR
In my experience the pro shift box requires a quick hard shift no matter the rpm. On the other hand my face plated box can be driven lazy (shift hard and fast - crunch) or pay a little attention and speed match it like a dump truck. After several fluid experiments I have stuck with Redline MTL it seems to do the beet job cushion the face plates when you get out of the throttle and the slop is taken up.
I think getting the clutch to slip would help a lot. If you are going to beat on it go find a g force 101a 4 speed and call it good.
Way back in 2014 my 9310 face plated gear set was over $1400. If I was doing it over I'd have put the money towards a g force 101a. It is more cost effective starting with a race box instead od converting a 45 year old 4 speed tto male ot live.
[Re: Jeremiah]
#2990446
11/30/21 11:42 AM
11/30/21 11:42 AM
Posts: 10,049 MN
JERICOGTX
MN
$1000 just to face plate a few gears? For $3000 I'll sell you a Jerico DR4, with a LONG vertigate shifter, ready to run...
69 GTX
68 Road Runner
[Re: tboomer]
#2990491
11/30/21 01:44 PM
11/30/21 01:44 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
$1000 just to face plate a few gears? For $3000 I'll sell you a Jerico DR4, with a LONG vertigate shifter, ready to run... Going to an automatic Jeff?? PEW PEW! Shots fired! ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif)
[Re: slantzilla]
#2990557
11/30/21 04:44 PM
11/30/21 04:44 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
My humble opinion, new brass rings, new slider, dump the clutch and go with a single disc system. Make sure your shift forks are in good shape. With regards to the main gears, dress up the cones with emery cloth. 80 grit is best.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: tboomer]
#2990755
12/01/21 06:56 AM
12/01/21 06:56 AM
Posts: 10,049 MN
JERICOGTX
MN
$1000 just to face plate a few gears? For $3000 I'll sell you a Jerico DR4, with a LONG vertigate shifter, ready to run... Going to an automatic Jeff?? No. I bought a Clutchless Liberty.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2992061
12/04/21 06:31 PM
12/04/21 06:31 PM
Posts: 97 western iowa
Z_Z
western iowa
I had liberty, faceplate, synchronize 1st gear, and side plate modification. I believe it was right around $1300, that was in 2014, so probably more now. Was a lot of fun behind my 431. Didn't have it long. Ended up going bigger motor, so ended up selling that setup off, and going auto. ![spank spank](/ubbthreads/images/graemlins/custom/spank.gif) To do over again, it been a jerico or a gforce.
