Re: 68 charger R/T positive battery cable
[Re: badblack68]
#299039
04/25/09 05:02 PM
04/25/09 05:02 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Mark, All the Chargers I've seen with original cables always went over the master or booster and down to the relay, not to say it's right or wrong?......I've tried other body applications, they all come up short, over or under the master/booster,....I know it's a hard pill to swallow, having a battery cable cost $250, but if you want it correct?,....either that or make your own? ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: badblack68]
#299041
06/10/09 11:59 PM
06/10/09 11:59 PM
Posts: 1,547 Seattle, WA
375inStroke
Special needs person
Seattle, WA
My '69 Charger R/T with power drums and original cable, routes over the booster. My rough measurements are: From the large lug of the relay to the breakout - 18". From the breakout to the center of the positive battery terminal - 19.5". My battery terminal was replaced with one of those P0S bolt on things, so it was originally longer. I'm replacing mine because of it. How does your repro cable compare? I saw this one from Bill Rolik Enterprises for $139: Battery Cable-Positive 68-70 B-Body Big Block Anyone buy from them? Who else sells these cables?
