Dana 60 question
#2990208
11/29/21 04:12 PM
11/29/21 04:12 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
Hi, is the third member replaceble for dana 60 .354 1968 from a 1979 dana 60 .354 from a f250. Thc
68 Satellite Wagon and a few other ones
Re: Dana 60 question
[Re: mro]
#2990286
11/29/21 09:10 PM
11/29/21 09:10 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
Hi, is the third member replaceble for dana 60 .354 1968 from a 1979 dana 60 .354 from a f250. Thc All the Dana Corp. rear ends I've seen do not had a "third member" the ring gear comes out the rear on the carrier and the pinion gear gears comes out the rear after the carrier (center section that the axles slide into) is remove, they are independent of each other. On the changing of the gears the Dana Corp made 3 or 4 different carriers for different ger ratios, the 3 series carrier works only on the 3:54, 3:73 and 4:10 ratio gears, the 4 series works on 4:56 up to 5:13, I think and the five series on the 5:57 and above gear ratios. There may be some other brand carriers and spools that will work on different ratio other than I listed
[Re: fastmark]
#2990383
11/30/21 07:39 AM
11/30/21 07:39 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Gear changing is a tricky job at best.
The pinion and carrier need ‘preload’ on the bearings.
This requires a ‘case stretcher’ for the Dana case, which is a hefty piece of kit.
I have build many third members and they is easy compared to a Dana...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: Gtxxjon]
#2990532
11/30/21 03:32 PM
11/30/21 03:32 PM
Posts: 6,389 Abilene, Texas
fastmark
Abilene, Texas
“Case spreader” is the technical term. You use a dial indicator to spread it .015. It’s pretty unnerving to stretch a case that is not easily replaceable that does not belong to you. .020 is too Much and might damage the case.
[Re: Cab_Burge]
#2990558
11/30/21 04:48 PM
11/30/21 04:48 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
That is basically the same way my friend put the gear set in his Dana 60 out of a B Body in his Camaro. He did not use a spreader.
1971 HEMI E BODY REGISTRY
[Re: fastmark]
#2990776
12/01/21 09:10 AM
12/01/21 09:10 AM
Gtxxjon
Isle of Sheeps
Wow I heard you could ‘mallet’ the bearings in, with preset preload, but prefer the stretcher myself. Obviously you need to set the backlash and add shims approx 0.007 to each side. I will give it a go and see how successful I am lol...
[Re: Gtxxjon]
#2990780
12/01/21 09:25 AM
12/01/21 09:25 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
At Mopar dealer we used to use the case spreader and do bearings and gear replacements/service while the differential was still in the vehicle. Not just for the dana 60, several diffs it was required (per manual) for ring and bearing service. I never did one on the bench with the diff removed. Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#2991130
12/02/21 01:44 AM
12/02/21 01:44 AM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
At Mopar dealer we used to use the case spreader and do bearings and gear replacements/service while the differential was still in the vehicle. Not just for the dana 60, several diffs it was required (per manual) for ring and bearing service. I never did one on the bench with the diff removed. Copper I have read and reread this at least a dozen times and I am still scratching my head. Are you maybe a little confused on which part is the differential? I have done at least 1000 Dana 44, 60 and 70 r&p setups and you are absolutely not going to change a r&p and bearings without removing the differential from from the case.
[Re: trw1982]
#2991203
12/02/21 11:16 AM
12/02/21 11:16 AM
Posts: 8,241 fredericksburg,va
cudaman1969
fredericksburg,va
Back in 1970 at the Dodge Shop we were told the 60 could only be spread maybe 3 times then a new housing. Told this by the Dodge rep and it was in the book too. I asked him why couldn’t you use the ‘spreader’ to pull it back once the case was empty? He just looked at me and shook his head while walking away. I use a long crow bar to get them out then a big hammer to drive it back in, tighter shims on the back side of ring gear, pinion holds the other side tight. Use checker bearings and original Miller set up tools, inch pound TQ wrench to check preload. Piss poor design but cheaper than making adjusters like an S60, 8-1/4, 9-1/4 8-3/4, 9”
[Re: cudaman1969]
#2991271
12/02/21 01:56 PM
12/02/21 01:56 PM
Cab_Burge
My current S/P car has a narrowed Dana 60 with Mark Williams 40 spline axles, two of his steel caps and it had one of his 40 spline aluminum spool with a set of Pro 5.86 gears when I got the car without a motor in it. I was told the rear gear ratio was either a 5:13 or 5:38 ratio, which with 16x33x15 tires should have worked fine with the 511 C.I. 400 E 85 stroker motor I put in it to race it. I got it running in the summer of 2013 and ran it once at a 1/4 mile track and fund out my stroker motor had its tongue out at 7300 RPM around the 1000 ft timers I check the gear ratio that winter and ended up finding out it had the 5:86 in it so I swap them out to a set of stock Dana 4:56 as I could not find a 40 spline 3 series 40 spline spool I wanted to put a set of 4:30 in it but I had to use the 4:56 gears and a Moser 40 spline steel spool as no one back then made a 40 spline 3 series spool I use two short pry bars to pry on two ring gear bolts to remove the spool and ring gear and installed the 4:56 pinion using a Pro Parts pinion depth checking tool kit I had to add .003 spacer behind the rear pinion bearing race to get the pinion depth within the specs. on that gear, it has worked fine until the last race of this year when the rear bearing cage failed in the pits allowing all of the bearings to fall out and lock it up I'm not sure what cause that but I will replace the bearing this winter and make sure none of the teeth on the ring gear and pinion gear are cracked or damaged and reuse that gear set if it checks out okay Luckily, I was warming it up in the pits and was going less than 2 MPH pulling into tech when the cage failed after I had put it in neutral to stop in tech I hate Murphy
[Re: Cab_Burge]
#2991518
12/03/21 07:37 AM
12/03/21 07:37 AM
Gtxxjon
Isle of Sheeps
I've done a DANA in a truck but it was a lot of 'huff-puff' working underneath! If you can only 'spread the case' three times then that's a worry indeed... Its not like a diesel head gasket with 'marks on' to show how many times its beeen done? When you do an 8 3/4 diff, the preload is adjusted from one side and if the mesh changes you can adjust it back. With a Dana the carrier preload is a bit 'hit and miss' with a guesstimate on side shims? Sometimes they feel 'tight' when rotated and you lessen the load. But they 'soften up' real quick in service and the preload goes away (with the fairies)...
