Re: Welder Purchase Advice
[Re: QuickDodge]
#2990017
11/28/21 11:49 PM
11/28/21 11:49 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a stick, Tig, and mig welder but I couldn’t run an aluminum spool gun on anything I owned so I just bought this on. I saved 100.00 joining the harbor freight club and another 10% getting their credit card. You can stick, mig, Tig, and run a spool gun with it. https://www.harborfreight.com/unlim...ess-welder-with-120240v-input-64806.html
[Re: pittsburghracer]
#2990044
11/29/21 02:00 AM
11/29/21 02:00 AM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
Hmmm - never heard of such a welder. Kinda cool. How does it work? I have a Century MIG that I bought back in the early 90's. It uses shielding gas & has infinite wire speed & heat dials. The wire speed is VERY sensitive (which is good), vs cheaper welder click-click settings. Wire speed is CRITICAL for good non-spatter welds. There are a few great-looking MIGS out there for under $1,000. Look at Hobart & Miller brands.
[Re: A12]
#2990060
11/29/21 06:46 AM
11/29/21 06:46 AM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
I can weld OK but I don't do it a ton. I mainly got a welder so I can have my friends that are good at welding weld things at my house lol. That being said I have become decent at it.
I have a Hobart 135 Mig. It is 110V but for a 110V machine it works very well, it has done some jobs beyond what is was rated for and done well. A friend was just asking me about it yesterday and I realized I have had it 12-14 years now. The biggest thing with a 110V machine is no extension cord and if you do have to have one it better be a good one or you can tell right away.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2990085
11/29/21 09:46 AM
11/29/21 09:46 AM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
If all you're doing is sheet metal, the Eastwood welders are a good bang for the buck. I have a Miller 252 which is a very nice 220v welder and will weld just about anything BUT I do a lot of thicker welding and didn't want to have to switch wire, rollers and liner every time I do sheet metal. I bought an Eastwood 135 110v machine and it works beautifully. I use a mixed gas and .023 wire and follow the suggested settings on the welder.
In this day and age, unless you're building bridges or fixing tractors in the middle of a corn field, I don't know why you'd want an arc welder. If you want to do thicker metals, buy a bigger mig. These days a quality 220v mig will have the capability to weld everything from tin foil to 1/2" with a change of wire rollers and whip liner. Those accessories are fairly inexpensive.
[Re: Stanton]
#2990093
11/29/21 10:19 AM
11/29/21 10:19 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I always say "welders are like garages, never big enough nor equipped fully", do yourself a favor invest in a quality machine, 220V, spool gun, etc, etc....Miller or Hobart, .....I have both mfg's MiG machines (Miller 252 and a Hobart 185), zero issues, as well as an AC/DC Arc welder and Miller Syncrowave 250 TiG.....buy it once, buy it right, buying cheap and underrated you'll kick yourself in the [censored] down the road....
[Re: DAYCLONA]
#2990107
11/29/21 10:58 AM
11/29/21 10:58 AM
Posts: 3,921 Richmond, Indiana
19swinger70
Richmond, Indiana
I have a Millermatic 251 I bought almost 20 years ago. Still going strong. Buy a good brand name, and get one with more capability than you currently need.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: J_BODY]
#2990358
11/30/21 12:30 AM
11/30/21 12:30 AM
Posts: 10,559 Freeport IL USA
poorboy
Freeport IL USA
I bought my Miller 252 30 years ago. Other then the whip, which has been changed 3 times, the machine is all original. I opened a one man welding shop about a year after I bought my Miller. It has been welding stuff together daily, Mon-Fri until I retired 32 years ago, Now it only gets used occasionally.
About 20 years ago I bought a Miller 210 because I needed a spool gun for welding aluminum, my 252 didn't have a spool gun attachment, and buying the 210 was about the same cost as having my 252 upgraded to accept the spool gun. When I retired, I sold the 210, and got all of my investment back + free use for 15 years.
Duty cycle isn't as important welding sheet metal as it is when you start welding 1/8" thick metal, but eventually exceeding the duty cycle with sheet metal will still kill the machine. My buddy bought one of those HF welders because he was only going to weld sheet metal. He had to replace that original HF welder after the 1st year. The next HF welder he bought was their top of the line 220v welder. Its about a year and a half old and is also starting to fail. Yes, he has exceeded the 60% duty cycle on it as well. At this point he has spent as much money as it would have cost him to buy a good Miller 220v with a 100% duty cycle.
Buy a good American built welder with a 100% duty cycle. Miller blue would be my choice. Gene
[Re: Stanton]
#2990419
11/30/21 10:31 AM
11/30/21 10:31 AM
Posts: 10,714 North Dakota
6PakBee
North Dakota
Only two comments, Miller and Auto-Set. I have one and it makes this hack look like I know what I'm doing.
[Re: 6PakBee]
#2990496
11/30/21 02:04 PM
11/30/21 02:04 PM
Posts: 22,696 Bitopia
jcc
Bitopia
IMO, buy the most powerful machine you can afford, I can't see as a hobbyist that duty cycle matters much, and forget anything flux core I have a hobart 140amp 120V mig (for 20+ years, and exceed the duty cycle all the time) With the cars, I find myself using the Hobart the most often.
[Re: jcc]
#2990503
11/30/21 02:23 PM
11/30/21 02:23 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
A Miller 211 will run on 110 or 220 and can operate a spool gun. The only thing that will hold you back is duty cycle if you are welding 3/16" for a while. Anything bigger than that and you will be looking at a Miller 252 or will go 1/2" however it is 220V only and no Autoset feature which comes in handy. Essentially Autoset allows you to flip a switch and the dial indicating material thickness and proportionately follows the voltage/wire speed table. In my experience it is pretty darn close for most projects if the metal is clean, etc. As with everything the prep and skill of the operator will make or break the performance of the machine.
[Re: Jeremiah]
#2990506
11/30/21 02:37 PM
11/30/21 02:37 PM
6PakBee
North Dakota
A Miller 211 will run on 110 or 220 and can operate a spool gun. The only thing that will hold you back is duty cycle if you are welding 3/16" for a while. Anything bigger than that and you will be looking at a Miller 252 or will go 1/2" however it is 220V only and no Autoset feature which comes in handy. Essentially Autoset allows you to flip a switch and the dial indicating material thickness and proportionately follows the voltage/wire speed table. In my experience it is pretty darn close for most projects if the metal is clean, etc. As with everything the prep and skill of the operator will make or break the performance of the machine. I think, THINK, Autoset must be more than that. If I manually set the voltage and wire speed, with clean metal I get an acceptable weld. If I go to Autoset, I get a great weld. I have the feeling, FEELING, that Autoset is always varying something while you are welding, wire speed or voltage or both, to obtain the best weld possible. Or I could be full of it.
