Trailduster spewing trans fluid like Mt Vesuvius! #2989954
11/28/21 07:41 PM
11/28/21 07:41 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
So I have been working on this 74 Trailduster. It has a 727 that was leaving like crazy from the pan gasket..or so I thought. I replaced the gasket, new filter etc...topped off the fluid. Fired it up and all looked good. No leaks. Then....I pulled it out of the garage, and was putting up by another building. When I stopped, smoke was rolling from under my hood. Popped it open, and there was trans fluid all over the engine. It looks like it was blasting up out of the trans dipstick tube. What the heck would cause this?
Dave in Colorado
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: dssaa] #2989982
11/28/21 09:06 PM
11/28/21 09:06 PM
A727Tflite Offline
A727Tflite  Offline
How much fluid did you add after dropping the pan?
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: A727Tflite] #2989985
11/28/21 09:16 PM
11/28/21 09:16 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
It was probably 5 quarts. Let it idle for a min and checked it and looked fine on the stick....
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: dssaa] #2989998
11/28/21 10:19 PM
11/28/21 10:19 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
did you check it in neutral?
my ladder of success is missing some rungs
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: rhad] #2990005
11/28/21 10:59 PM
11/28/21 10:59 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Yep....neutral.
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: dssaa] #2990022
11/29/21 12:03 AM
11/29/21 12:03 AM
A727Tflite Offline
A727Tflite  Offline
Not uncommon for it to throw fluid out the vent and sometimes the dipstick if you add all the oil real quick.
I would just clean it up and monitor.
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: dssaa] #2990042
11/29/21 01:55 AM
11/29/21 01:55 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If not overfilled, it could be the vent is plugged.
Seen it on transmission converted to rear vent, and the vent tube got too close to header and melted venttube closed, then trans fluid blew out dipstick tube
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: dssaa] #2990047
11/29/21 02:18 AM
11/29/21 02:18 AM
Boise
Moparteacher Offline
Boise
You may want to pressure test the cooling system, and check for transmission fluid in the coolant.
Unlikely, but worth a look.
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: Moparteacher] #2990091
11/29/21 10:12 AM
11/29/21 10:12 AM
Washington
madscientist Offline
Washington
I had something similar happen way back in 1995. I had a 66 Fury that was my daily driver and it was constantly leaking transmission oil. I could never find the leak. So I said screw it and drove it, adding oil when it needed it. On my way home from work one day I could really smell ATF on the exhaust and I’m thinking WTH??? And then in an instant it looked like I was crop dusting. Fortunately I was 2 blocks from my house so I got it home. I pulled it into the alley so it didn’t drip oil all over the driveway or my shop floor and let it drip for a few hours. Once I wiped everything down so I could see what was going on, I found one of the cooler lines had split. Right in the seam. So that thing was leaking from that seam for a long time before it blew like a death aneurism. And it was impossible to figure out where the leak was coming from because the air under the car would coat the underside of the car with ATF so it looked like it leaked everywhere. Once I fixed that it was dry as a bone.
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: A727Tflite] #2990106
11/29/21 10:57 AM
11/29/21 10:57 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by Transman
[Not uncommon for it to throw fluid out the vent and sometimes the dipstick if you add all the oil real quick.
I am in no way questioning your knowledge and appreciate all the help you provide on this forum. But I am curious as to what would cause the above?
One can only put the fluid in as fast as gravity and the dipstick tube will allow unless of course one is somehow pressurizing the fluid and forcing it in. Even then I'm trying to understand what would cause it to burp the fluid unless of course as previously mentionned the vent in the pump suddenly became plugged which seems unlikely. confused shruggy
Again, thank you and Mr. Kunkle for all the help you both provide up
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: madscientist] #2990119
11/29/21 11:45 AM
11/29/21 11:45 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Originally Posted by madscientist
I found one of the cooler lines had split. Right in the seam. So that thing was leaking from that seam for a long time before it blew like a death aneurism...
I had something similar when I bought the '65 Satellite. I was taking it apart for restoration - and I found the trans cooler lines were routed wrong by a prior owner. One of the trans cooler lines was rubbing against a chassis part and was worn razor thin. Must've been that way for years.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: TJP] #2990130
11/29/21 12:16 PM
11/29/21 12:16 PM
A727Tflite Offline
A727Tflite  Offline
Assuming you added the fluid when they trans was cold - thermal expansion and fluids being slung around during fill can cause the vent or dipstick to leak.
The dipstick tube is downwind from rotating parts so that can add to the issue.
Depending how long the pan was off, the converter drains a tad as well. Expelling fluid/air from the converter adds to the issue.
“In plant” fill at the assembly plants had us doing a step fill. To prevent false leaks.
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: A727Tflite] #2990288
11/29/21 09:20 PM
11/29/21 09:20 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
This is all great information. I am going to run it again tomorrow after work and just watch things. I will update when I know where the source is...
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: A727Tflite] #2990313
11/29/21 10:19 PM
11/29/21 10:19 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Hmm, never heard or experienced it, thanks for the response wink
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: TJP] #2991684
12/03/21 02:49 PM
12/03/21 02:49 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hello,
at one time race car would shoot fluid out dipstick tube when shut off. was never able to fix, converter, valve body change etc. cracked case ??? heat sink cooler mounted on firewall above tranny air bond??? ended up changing tranny
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: 440lebaron] #2991722
12/03/21 04:39 PM
12/03/21 04:39 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by 440lebaron
hello,
shruggy
Would have more questions but since the trans has been replaced I guess all we could do now is guess.
Best guess, a real rapid increase in heat buildup after shutdown expelling fluid out. Why? Dunno.
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: A727Tflite] #2991834
12/03/21 10:03 PM
12/03/21 10:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
hello,
shruggy
Great guess IMO, The why would be the fluid getting too hot which you stated and makes perfect sense, Only other thing i could think of is being overfilled due to the wrong dipstick/tube beer
Re: Trailduster spewing trans fluid like Mt Vesuvius! [Re: TJP] #2991974
12/04/21 01:00 PM
12/04/21 01:00 PM
moparx Online content
moparx  Online Content
i'm for thinking it would be the heat sink cooler on the firewall. horizontal in and out tubes [?] causing air in the system when the engine was shut off, and the fluid was suddenly dumped back into the transmission. however, since the transmission was changed, and it stopped, [still using the horizontal firewall mounted cooler ?] that throws out my thoughts, so ? shruggy
i realize factory coolers in front of the radiator are as high [?] but they usually have bottom in/out tubes.
beer
