Page 3 of 3 1 2 3
Re: Who's got build plans this winter? [Re: Dragula] #2989377
11/26/21 05:50 PM
11/26/21 05:50 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Motor was new last year in mine….so, gonna upgrade to a Dana over the winter and sell my 8.75 i just put a brand new Moser pumpkin in to help with the S60 cost.
Then i will start using my brake i have yet to try.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Who's got build plans this winter? [Re: B3422W5] #2989387
11/26/21 07:19 PM
11/26/21 07:19 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Installing a new R5 P7 motor going back to a good 904 sold the powerglide my plate is done now just swing on a couple things so I can get it in the car and get everything mocked up then pull it back out to repaint the engine compartment
Re: Who's got build plans this winter? [Re: scottb] #2989504
11/27/21 07:02 AM
11/27/21 07:02 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Like some on here I'm struggling to get parts, frustrating really as we are in a situation where we have the time and finance for once frown (retiring in 6 weeks or so grin ) being across the water doesn't help either. A big wheelstand ended the season early for us so we ran my wifes 68 Barracuda for the rest of the season,( and eventually got it into the 13's laugh ). Still on repairing / replacing parts from that wheelie. This winter we are replacing the old data logger and going to Racepak, we had to go to a V300 as the grid takes up a lot of sportsman channels. Long term I'm looking to finish the 655, go TH400 ( or similar), and 9" then hopefully bust into the 8's cool .
Re: Who's got build plans this winter? [Re: Tig] #2989510
11/27/21 08:54 AM
11/27/21 08:54 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Yes sir......those willies can be a crowd pleaser but get expensive tsk
Re: Who's got build plans this winter? [Re: racerx] #2989517
11/27/21 09:43 AM
11/27/21 09:43 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Yep that's the 3rd time we've done so. Damaged the headers, oil pans, moved the fenders, bent the wheelie bars and it normally needs a front end re-alignment so somethings moving. We're taking gear out of it and likely will experiment with timing at the hit next season. What we've found is that we can set it perfectly at one meeting, at the next, it either spins or wheelstands excessively. It's just not consistent, we've also found the slicks (M/T radials) are very sensitive to track temp, so we're moving to Hoosier radials of the same size as we hear they are a little more forgiving with track temp, next time they need replacing.
Re: Who's got build plans this winter? [Re: Tig] #2989759
11/28/21 02:21 AM
11/28/21 02:21 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Last year I tackled a minitub and spring relocation project, so I’m trying to go easy this winter. But I’m still excited to see what the changes may yield in the spring.
I’ll (Finally) be swapping out my Performer RPM for an M1. The RPM was a good choice originally when the car was in the 12’s. I’m now knocking on the 10 second door and trapping at 6600rpm; I hope the move to a decent single plane will yield some improvement on the big end. I’m also getting rid of the cars original power steering in favor of a 16:1 manual box. That should save at least 25 lbs, and improve the cars feel at the same time. I may also try to find a few pounds in the stone stock front bumper with guards and brackets.
The car ran a best of 11.07 last year. If things go well, next year just might be the year we pick up a 10-second time slip.
Also going to make some additions in the trailer. A winch, a workbench, LED lighting, and floor coating should keep me busy.
Re: Who's got build plans this winter? [Re: StealthWedge67] #2989779
11/28/21 10:02 AM
11/28/21 10:02 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
On my small block A body going from power to manual steering saved almost 39 pounds.
Re: Who's got build plans this winter? [Re: justinp61] #2989851
11/28/21 02:23 PM
11/28/21 02:23 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Just working on the Cuda I got my friend a 1972 Pro stock that started life as a 1971 Cuda. Taking most of the stuff out that was changed after 1972 and returning it back to the car that was raced in 1972 right down to the paint scheme. Need to do some floor repair from the mods that were done over the years and that is almost done. Everything floor, roll bar, new frame connector is ready to be welded and then will build the New Hemi and either a Clutch Flite or a 727 with A&A internals and then finish the interior off. Build or rebuilding a car sure is a learning experience taking out the mistakes that were done over the years and returning it to is Division Championship form. Sure is a learning experience over the last year of so.
1971 HEMI E BODY REGISTRY
Re: Who's got build plans this winter? [Re: hemicar1971] #2990299
11/29/21 09:42 PM
11/29/21 09:42 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Switching from FAST to Holley.
Re: Who's got build plans this winter? [Re: FastmOp] #2990314
11/29/21 10:22 PM
11/29/21 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Which Holley are you going with HP or the Dom
wave
Re: Who's got build plans this winter? [Re: MR_P_BODY] #2990403
11/30/21 09:49 AM
11/30/21 09:49 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’ve had a big case of the “I don’t cares” and the car has sat silent since Labor Day…. at least it’s getting cool enough to where I could actually store it in the trailer now. Hopefully this spring I’ll be motivated to get out, but my closest track is 2hrs away (Vegas… never race there) and my favorite track is a 5hr pull. That’s getting a bit expensive these days. Gonna be a fire sale one day….
Re: Who's got build plans this winter? [Re: MR_P_BODY] #2990414
11/30/21 10:20 AM
11/30/21 10:20 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
wave
Dominator with the msd 600 coil on plug deal.
Page 3 of 3 1 2 3
