Re: School me on R&R engine from bottom
[Re: BDW]
#2989349
11/26/21 03:33 PM
11/26/21 03:33 PM
Posts: 20,574 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
All the pictures and videos where this is being done the trans and engine are bolted together. If you leave the transmission in place you have to figure out how to support it as well. Also need to make sure the engine picker legs and wheels stay clear of the engine cart. Rear wheels can be left on the car and on the ground. Couple YouTube videos on it out there to help see it in action. Here is one with the body still on caster wheels in the back. https://youtu.be/8HHQqGnU5DQ
[Re: Neil]
#2989392
11/26/21 07:25 PM
11/26/21 07:25 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
You disconnect all the usual stuff, plus disconnect the coupler of the steering shaft from the steering box, remove the front shocks, remove the torsion bars, uncouple the lower ball joint studs from the spindles. It works nice to build some kind of cart on caster wheels with some supports on it that will hold up the K frame and the transmission. Lower the car enough that the K frame and the transmission are sitting on the cart. Take out the 4 K frame bolts, remove the transmission cross member, then lift the body off of the engine / transmission / k-frame assembly. What you lift it with depends on your situation. I like to do it with the car on the hoist so that I can safely and easily lift the body. If you don't have a hoist, I think it's going to be a lot harder. You need to get the car up in the air pretty high. If I didn't have a hoist, I think I'd pull it out from the top. I think it would be a lot easier.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2989397
11/26/21 07:32 PM
11/26/21 07:32 PM
Posts: 3,076 Michigan
A727Tflite
This is how the factory did it.
[Re: A727Tflite]
#2989424
11/26/21 08:42 PM
11/26/21 08:42 PM
Posts: 608 TN
1DGEMAN
TN
It is very easy to do from the bottom.
Real Men shift for themselves
[Re: BDW]
#2989443
11/26/21 09:55 PM
11/26/21 09:55 PM
A727Tflite
Good info and video, I'll add this is going to be only me doing this by myself. I bought the HF 2T lift, but it looks like way more stuff needs to be disassembled and put back together when going in from bottom. Seems to be perfect for a car under going a full resto. I don't mind the extra work if that makes sense, just worried getting everything aligned from bottom might be tougher compared to dropping in from top, if I'm doing this alone?
I also don't see buying a dolly for an engine/trans combo, unless maybe a couple of HF wooden types could work.
Thx I have seen several wooden bucks that guys built themselves. Just make sure you have good casters that will hold the weight. And get the height close for the buck. I would suggest you measure from the ground up to the longitudinals where the k frame attaches and mimic that on the buck. For the trans you may want to raise or lower that with a floor jack to get the cross member in.
[Re: BDW]
#2989491
11/27/21 02:29 AM
11/27/21 02:29 AM
Posts: 608 TN
1DGEMAN
TN
Thx I did that install myself in a 2 car garage. The engine trans dolly was an old toolbox frame with an added cross member. Quite simple and uneventful. I have done it this way on A bodies also. I also built my own run stand.
[Re: AndyF]
#2989542
11/27/21 11:11 AM
11/27/21 11:11 AM
Posts: 4,727 Florida
BDW
It is a the right way to do it but it requires a bunch more equipment and space. Doesn't sound like you're set up for it. You're probably right, underneath seems great if the car is already apart. It looks like the valance and bumper would also need to be removed at a minimum. No to mention the steering, K-frame, separating ball joints, torsion bars, etc........................ And then I'd have to build/buy some sort of brackets for lifting.
[Re: BDW]
#2989564
11/27/21 12:56 PM
11/27/21 12:56 PM
Posts: 6,258 nowhere
Sniper
nowhere
It is a the right way to do it but it requires a bunch more equipment and space. Doesn't sound like you're set up for it. You're probably right, underneath seems great if the car is already apart. It looks like the valance and bumper would also need to be removed at a minimum. No to mention the steering, K-frame, separating ball joints, torsion bars, etc........................ And then I'd have to build/buy some sort of brackets for lifting. That's the hard way of doing it. Most just unbolt the UCA inner pivots, disconnect the steering coupler, unwire it, remove the radiator and hoses, take out the four K member bolts and drop it out on the K member. How you lift the body varies depending on what you have to lift with but a couple of extensions mounted to where the bumper brackets bolt up and lifting with those can do the trick.
[Re: BDW]
#2989571
11/27/21 01:24 PM
11/27/21 01:24 PM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
It is a the right way to do it but it requires a bunch more equipment and space. Doesn't sound like you're set up for it. You're probably right, underneath seems great if the car is already apart. It looks like the valance and bumper would also need to be removed at a minimum. No to mention the steering, K-frame, separating ball joints, torsion bars, etc........................ And then I'd have to build/buy some sort of brackets for lifting. Nice car and shop, Andy. No need to take the front valence or bumper off. I use a homemade jig to lift the car with my engine hoist and the rear end on jack stands. The jig has to bolts welded at either end that fit into one of the factory holes in the bottom of the frame, so the jig can't slip out of position. The jig goes between the frame rails approximately where the radiator goes.I don't have to remove the hood either. I do have to remove the rear valance to lower my exhaust. To roll the engine/trans out from under the car, I use a simple furniture dolly. The nice thing about doing it this way is that the headers and accessory drives can be assembled while the powertrain is out of the car. I did pull my transmission first, so I would not have to bleed my hydraulic throwout bearing. This time I separated the lower ball joints and left the discs, shocks and upper control arms in place on the car. I usually work alone on my stuff, and am careful to use good safety practices to avoid injury.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2989594
11/27/21 02:14 PM
11/27/21 02:14 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Anything engine related on any of my 3 cars goes out the bottom...
Rear wheels on the ground...
Engine crane with a bracket similar to the one posted above that drops in once the radiator is removed...
Unbolt everything up top...
Lift the car up on to jack stands... remove driveshaft... loosen but leave in place the 4 bolts for the trans crossmember... separate collectors from headers... separate lower ball joints leaving all brakes...spindle and rotor together and tie up into wheelwell... remove torsion bars and steering column shaft from box...
I then raise the car up and put my dolly in under the engine and transmission...
Lower the car down and remove the 4 K frame bolts and the 4 trans crossmember bolts...
Lift the car up and then roll the engine and trans out with the K frame...headers...starter and everything else attached...
Lower the car back down onto the jack stands until its time to repeat the process in the opposite order...
...FAFO...
[Re: AndyF]
#2989849
11/28/21 02:19 PM
11/28/21 02:19 PM
Posts: 19,408 north of coder
moparx
in all my years of replacing engines, i never once took one out the bottom. you guys almost have me convinced to do that when i finally get around to swapping the engine in my charger. however, i'm afraid of "mission creep", deciding i need/want to do more things to it, and the car has been down way too long as it is, and i ain't getting any younger ! i can fab up just about any tool or fixture i may need for any repair or modification of any item.
