Thank you both for the insight. I assumed they were speedmaster/procomp and to be avoided.
I bought my set used and have been running them since 2014. So how old they are I don’t know. I may have asked the guy but that was 2014 and I just can’t remember if I did or not. But the adjusters and all the rest are fine. The reason the guy sold them is he was having “issues” with the geometry and he did the tried and true lash cap deal and it didn’t work so he took them off and sold them.
I don’t run a ton of cam, but it did take a fairly big correction kit from B3 to get the geometry correct. At .620 lift with a standard small block stem height I thought it was a pretty big correction any way. I’ve heard the bushings are soft, but mine are still in there.
I wouldn’t be afraid to use them.
