Re: wing on the back of a 68 Dodge Dart [Re: FastmOp] #2988656
11/24/21 02:03 PM
11/24/21 02:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted by FastmOp
You need a spoiler not a wing. A small wickerbill and decent spill plates.
Jerry Bickle has a nice carbon piece that's reasonable and easy to fit.
The car will drive better.
True.. mine is a spoiler (not a wing).. I used the wrong wording.. its all home made
wave
Re: wing on the back of a 68 Dodge Dart [Re: HardcoreB] #2988683
11/24/21 04:19 PM
11/24/21 04:19 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Quote
None of your pics are working for me Slant.?
I see them. ??????
Re: wing on the back of a 68 Dodge Dart [Re: slantzilla] #2988719
11/24/21 05:38 PM
11/24/21 05:38 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Options
"Any fool can know. The point is to understand"
- A. Einstein
Re: wing on the back of a 68 Dodge Dart [Re: EvilB1Dart] #2988742
11/24/21 06:31 PM
11/24/21 06:31 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
There is a guy from Utah that used to come up here with a 70 Challenger that had a built W9 stickshift smallbock that ran low 8s @ 150+ in the quarter. Car had some fiberglass parts on it, but the body design was stock other than he put a clear lexan screen in front of the grill opening to keep the air out. I think I would try blocking the grill off first before a rear wing myself. Also a chin spoiler would be good too depending on ride height.
Re: wing on the back of a 68 Dodge Dart [Re: WHITEDART] #2988858
11/25/21 12:46 AM
11/25/21 12:46 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I have ran the grill blocked off for several years it was good for 1MPH in the 8th.. And a small spoiler Is that I had taken off of a Ford Ranger... I think They need to be closer to the ground I just Looking at some other options
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: wing on the back of a 68 Dodge Dart [Re: WHITEDART] #2988859
11/25/21 12:50 AM
11/25/21 12:50 AM
bean town ....Ca
W
W
bean town ....Ca
I have looked at the front of this car for quite some time... Minus That opening
Re: wing on the back of a 68 Dodge Dart [Re: WHITEDART] #2988862
11/25/21 12:58 AM
11/25/21 12:58 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
68/69 camaro chin spoiler was a pretty common use
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: wing on the back of a 68 Dodge Dart [Re: WHITEDART] #2989118
11/25/21 08:06 PM
11/25/21 08:06 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I forget the guys name but he is on NPK's , pretty fast Dart, might look at what he has & also Dominator's Dart has a rear wing, spoiler, , just a thought
Randy Williams is the other guys name
Re: wing on the back of a 68 Dodge Dart [Re: CSK] #2989234
11/26/21 09:39 AM
11/26/21 09:39 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
A 79 Malibu chin spoiler will fit fender to fender pretty good . Some fiberglass work makes it perfect
....BAD A$$ STREET CAR.....
Re: wing on the back of a 68 Dodge Dart [Re: n20mstr] #2989238
11/26/21 09:54 AM
11/26/21 09:54 AM
N
n20mstr Offline
n20mstr  Offline
N
Don’t know what front suspension your running , but getting it low helps a lot also . I’m about to lower mine a lot , front as well as the rear . These darts also have a pretty large trunk already so it doesn’t take much wing back there to make a difference . As mentioned data logging the rear shocks will show if the wing is adding downforce . I don’t run any rear wing at all , at least not yet .
Re: wing on the back of a 68 Dodge Dart [Re: WHITEDART] #2989402
11/26/21 07:40 PM
11/26/21 07:40 PM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
My 68 Dart made a big difference in stability when I had it even with the car sitting in the weeds. I wish I still had my Dart!
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
