Electrical Gremlins - 68 Barracuda won't start when hot #298917
04/25/09 09:32 AM
04/25/09 09:32 AM
BC, Canada
D200 Offline OP
D200  Offline OP
BC, Canada
I have a 68 barracuda with a 440. It starts well when cold and runs great for as long as i want. After i stop and it sits a while it won't start. It cranks over well but won't start and it's not overheating. I have an MSD 6AL and MSD distributor. I just replaced the coil, still same problem. There is gas coming through the holley 850. Anyone please give advice on where to start?
D200
Re: Electrical Gremlins - 68 Barracuda won't start when hot [Re: D200] #298918
04/25/09 09:43 AM
04/25/09 09:43 AM
Anyone please give advice on where to start? Thanks
When it's hot & acting up is there spark w the coil wire 1/4" from ground with someone cranking?
Re: Electrical Gremlins - 68 Barracuda won't start when hot [Re: D200] #298919
04/25/09 11:27 AM
04/25/09 11:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you tried going wide open on the gas pedal
while cranking.... it might be boiling the fuel
(which expands and dumps into the intake making
it a flooded condition) check the float levels.
As said check for spark
Re: Electrical Gremlins - 68 Barracuda won't start when hot [Re: MR_P_BODY] #298920
04/26/09 01:25 PM
04/26/09 01:25 PM
BC, Canada
D200 Offline OP
D200  Offline OP
BC, Canada
It's the msd box! Thanks for the advice. Bypassed the box and it fires up when hot too.
