1965 B Body Rear Window Trim Removal #2988493
11/23/21 10:19 PM
11/23/21 10:19 PM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
Reaching out to see if anyone has any guidance on how to remove the trim around the rear window on a 65 Coronet 500. Have successfully removed all the trim except for this piece. Appears to be a very small spring loaded clip that needs pulled up independent of the trim and then it pops out but none of the tools I have tried so far are small enough to get behind it. Posted on B Bodies only and was suggested it was same as front. It is not the same as front so hoping someone on here has some insight.
Thanks in advance.
Re: 1965 B Body Rear Window Trim Removal [Re: BryanRad] #2988527
11/23/21 11:41 PM
11/23/21 11:41 PM
I think you need the special trim removal tool to open them up to remove the trim, I don't know the name or brand sorry confused
Is Ripley CA were you live?
The reason I'm asking is I lived in Blythe in the late 1950 up to Nov.1961, haven't been back to Ripley or Palo Verde since then shruggy
Hopefully the entire Palo Verde Valley is still mainly farming and ranching luck
Re: 1965 B Body Rear Window Trim Removal [Re: Cab_Burge] #2988565
11/24/21 08:16 AM
11/24/21 08:16 AM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
I have tried a tool or two so far to no avail.
Sorry, Ripley WV.
Thanks for the reply.
Re: 1965 B Body Rear Window Trim Removal [Re: BryanRad] #2989497
11/27/21 03:16 AM
11/27/21 03:16 AM
Sorry, Ripley WV.
Nothing to be sorry about, isn't that coal mining territory?
Re: 1965 B Body Rear Window Trim Removal [Re: Cab_Burge] #2991835
12/03/21 10:03 PM
12/03/21 10:03 PM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
Well my body guy figured it out. So for anyone needing to know, here is the answer.
Re: 1965 B Body Rear Window Trim Removal [Re: BryanRad] #2991999
12/04/21 03:08 PM
12/04/21 03:08 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Hey Bryan
I'm trying to get a handle on the "correct" clips for the window trim clips sets. Can you share a a picture (and qty count) of the clips? Also a measurement of the longest side. Most companies sell a green clip that "looks" similar. But I had a local customer with a 65 Belvedere that brought a clip that, again, looked similar but was larger. The green ones being sold are like 1" wide and the one the customer showed me was like 1-1/2" wide. Maybe the green one work, just a different size.
Thanks!
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 1965 B Body Rear Window Trim Removal [Re: 71TA] #2992121
12/04/21 11:13 PM
12/04/21 11:13 PM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
Will do. Need to get a few more for mine on the lower side. Some of the folks on B Bodies only say the Ford or similar clip will work. PM me if I forget to post here please.
