You need a spoiler not a wing. A small wickerbill and decent spill plates. Jerry Bickle has a nice carbon piece that's reasonable and easy to fit. The car will drive better.
True.. mine is a spoiler (not a wing).. I used the wrong wording.. its all home made
Re: wing on the back of a 68 Dodge Dart
[Re: HardcoreB]
#2988683 11/24/2104:19 PM11/24/2104:19 PM
There is a guy from Utah that used to come up here with a 70 Challenger that had a built W9 stickshift smallbock that ran low 8s @ 150+ in the quarter. Car had some fiberglass parts on it, but the body design was stock other than he put a clear lexan screen in front of the grill opening to keep the air out. I think I would try blocking the grill off first before a rear wing myself. Also a chin spoiler would be good too depending on ride height.
[Re: WHITEDART]
#2988858 11/25/2112:46 AM11/25/2112:46 AM
I have ran the grill blocked off for several years it was good for 1MPH in the 8th.. And a small spoiler Is that I had taken off of a Ford Ranger... I think They need to be closer to the ground I just Looking at some other options
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2988859 11/25/2112:50 AM11/25/2112:50 AM
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: WHITEDART]
#2989118 11/25/2108:06 PM11/25/2108:06 PM
I forget the guys name but he is on NPK's , pretty fast Dart, might look at what he has & also Dominator's Dart has a rear wing, spoiler, , just a thought Randy Williams is the other guys name
[Re: CSK]
#2989234 11/26/2109:39 AM11/26/2109:39 AM
Don’t know what front suspension your running , but getting it low helps a lot also . I’m about to lower mine a lot , front as well as the rear . These darts also have a pretty large trunk already so it doesn’t take much wing back there to make a difference . As mentioned data logging the rear shocks will show if the wing is adding downforce . I don’t run any rear wing at all , at least not yet .
....BAD A$$ STREET CAR.....
[Re: WHITEDART]
#2989402 11/26/2107:40 PM11/26/2107:40 PM
My 68 Dart made a big difference in stability when I had it even with the car sitting in the weeds. I wish I still had my Dart!
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
