Re: What have you done to reduce vehicle weight?
[Re: migsBIG]
#2987661
11/21/21 10:24 PM
11/21/21 10:24 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
The list is almost endless. Some biggies: Lithium battery on the framerail under the drivers floor. Save 60# at least of battery and cable compared to lead acid in the trunk. aluminum calipers, aluminum hats, 50+# compared to stock Aluminum flywheel and pressure plate 20#+ acid dip bumper brackets 12#
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2987662
11/21/21 10:27 PM
11/21/21 10:27 PM
Posts: 3,096 Michigan
A727Tflite
That old saying that saving 100lbs pounds of weight off a race car can be equal to tenth in the quarter. Or not. Possible true by accident, not linear. Boff, is there an accurate formula or calculation that we can use? Try the Wallace calculator. Start with a given horsepower, then plug in weights starting at maybe 4k and work downward to maybe 2500. You should see a decrease in e.t. reduction as you work away from 4K. Chrysler used to use a tenth decrease per 100 lbs. removed. But that was typically for most doorslammers back in the day at 3300-3600 lbs.
[Re: A727Tflite]
#2987666
11/21/21 10:34 PM
11/21/21 10:34 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
[quote=Hemi_Joel][quote=polyspheric]That old saying that saving 100lbs pounds of weight off a race car can be equal to tenth in the quarter.
That was in the heyday of Jr. stock and Super Stock, 1960 to around 1974
[Re: Cab_Burge]
#2987680
11/21/21 11:33 PM
11/21/21 11:33 PM
Posts: 9,873 MI, usa
dvw
MI, usa
My 64 Belvedere just under 3100 w/o driver. The heavy stuff; Mega block, Dana, all steel body stock floor and trunk pans, inner fenders, ect, except hood, std battery, stock steering wheel, steel bumpers. The aluminum parts; seat to floor brackets, brake hubs, calipers, master cylinder, radiator, fuel cell, driveshaft, trans shield, heads, intake, water pump, valve covers, motor plate, shocks, wheels, hood pins, carb air pan, trans drums, front clutch carrier. The missing stuff; heater, wipers, window regulators. The modified stuff; moly tube cage, steering shaft, strut rods, fender braces, center grille support. K frame is cut down, cast zinc cluster is 1/8"aluminum plate. The light stuff; Lexan windows (exc windshield) with nylon straps for functional door windows, vents are Lexan, small alternator. The trick light stuff; magnesium seat frames (seats and brackets together weigh 18lbs each) , carbon fiber bumper brackets (2.5lbs total for all), carbon fiber hood and scoop (17lbs). The extras; plenty of extra cage bars that weren't required for 8.50 cert, fire system, vacuum pump, large radiator, dual fans, 2 carbs, slick tubes. Stuff that I like but is heavy; stock steering wheel and horn ring, cast American 200S wheels, cast valve covers. Except for the safety equipment the exterior and interior appear pretty much stock. Doug
[Re: dvw]
#2987701
11/22/21 04:29 AM
11/22/21 04:29 AM
Posts: 20,208 Park Forest, IL
slantzilla
Park Forest, IL
100# off a car with 100 horsepower makes a much bigger difference than 100# off a car with 1000 horsepower.
[Re: polyspheric]
#2987733
11/22/21 09:39 AM
11/22/21 09:39 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Look at it as a percentage of weight. 100lbs off of a 7000lb truck is a drop in the ocean compared to 100lbs off of a 2500lb car.
On one of my cars I dropped weight from 3199 to 2987 and picked up 3 tenths and 3mph on the rev limiter through the traps.
I've done nothing but add weight to my chubby 69 Charger with an iron hemi.
At the very least I plan to replace the steel wheels with aluminum look-alikes from Bogart.
[Re: dOc !]
#2988675
11/24/21 03:42 PM
11/24/21 03:42 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
Nothing. No lightweight. 3760 full race weight,, full cell, both bottles and me in it.. Okay, I do have aluminum Kirkey seats, lightweight racing battery, aluminum wheels, fiberglass hood. All else is all steel, factory windows, full interior, exhaust and street driven.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: polyspheric]
#2988694
11/24/21 04:32 PM
11/24/21 04:32 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
That old saying that saving 100lbs pounds of weight off a race car can be equal to tenth in the quarter. Or not. Possible true by accident, not linear. It's not linear. Lighter the car, the more it matters. HP level also matters some. Depending on the weight & HP, it's close - within a few hun either way. Take it out of a wheel/tire or anything else reciprocating or spinning, it makes a bigger difference. Where the weight is also matters. Front. rear, and/or how far from C/G in any direction, all make it work differently.
