99 Ram V10 thermostat #2987005
11/19/21 10:29 PM
11/19/21 10:29 PM
Sonoran desert, Arizona, USA
moparjo68 Offline OP
Hoping someone will know the Mopar part number for a 195 degree thermostat to fit a 99 ram v10 2500. It is definitely NOT part number 52028185AC that rockauto has listed in their v10 thermostat lineup. The thermostat I need fits down into a 3 inch metal seal. Its a very odd setup. I am not looking for aftermarket part numbers.
Re: 99 Ram V10 thermostat [Re: moparjo68] #2987022
11/20/21 12:04 AM
11/20/21 12:04 AM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
Try p/n 53041087AC. It looks like what you are describing. Paul TRW1982 is correct, the p/n is 53041078AC , I typed it in wrong
Re: 99 Ram V10 thermostat [Re: iapco103] #2987118
11/20/21 10:48 AM
11/20/21 10:48 AM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
I got one from Napa don't know part no.
Re: 99 Ram V10 thermostat [Re: iapco103] #2987174
11/20/21 01:42 PM
11/20/21 01:42 PM
I tried the part number 53041087AC into many different sites. Its producing no results.
Re: 99 Ram V10 thermostat [Re: moparjo68] #2987182
11/20/21 02:36 PM
11/20/21 02:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I tried looking for a factory T stat for my 99 V10 2500 Ram (so little support for these vehicles aftermarket or factory), everything that was supposedly factory PN#'d that I bought of Ebay ended up in the trash because it didn't fit, the best results I've had is with the Murray brand T stat set up from AutoZone/O'Riely's (been running it about 3 yrs now, no issues)....it is quite an oddball set up, if you haven't change one before there's 3 pcs required, the 6 bolt housing gasket, the T stat and the large ring seal that's pressed into the manifold under the T stat... you'll need a few slide/seal pullers to pop the factory cast brass T stat and ring seal...fun job!
Mike
Re: 99 Ram V10 thermostat [Re: DAYCLONA] #2987240
11/20/21 06:15 PM
11/20/21 06:15 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
op, not sure how or where you looked up the number but 53041078, 53041078ab, 53041078ac comes up all over www. says it fits dodge 2500, 3500, viper v10. also napa number for 180 deg is 613080, 190 is 613090.
Re: 99 Ram V10 thermostat [Re: DAYCLONA] #2987298
11/20/21 08:53 PM
11/20/21 08:53 PM
OK. The last 4 numbers are 1078. I was putting in 1087. That makes a difference. No. Its anything but fun in removing and replacing a thermostat for the 99 ram v10. I did find out, after trying many different ways to remove the metal seal thats pressed into the manifold, there is an easier way. I just took a large punch and hammered one side of seal as though I was driving it down. One side of seal went down, the other side went up and I was able to grab it. I learned this after fighting with it for over 30 minutes. Thanks for your help Moparts community!!!!!
Re: 99 Ram V10 thermostat [Re: moparjo68] #2987587
11/21/21 05:29 PM
11/21/21 05:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I scored a MINT V10 aluminum tstat housing last year. Had no problem finding a buyer. Wish I could have scored the front engine/timing cover, but the yard was closing up for good.
Re: 99 Ram V10 thermostat [Re: J_BODY] #2988074
11/23/21 12:49 AM
11/23/21 12:49 AM
I could not believe what the aluminum thermostat covers were going for on ebay. Used. Nearly 300.00. Unreal. But if you need it, you'll pay it. Anyone know anyone who might have a v10 thermostat for sale? Mopar. No aftermarket.
Re: 99 Ram V10 thermostat [Re: moparjo68] #2988658
11/24/21 02:16 PM
11/24/21 02:16 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My 96' Ram V10 had the black plastic housing originally. I bought a replacement cast aluminum housing back in the early 2000's. I think it was $90.00+ back then from the dealer.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 99 Ram V10 thermostat [Re: moparjo68] #2988882
11/25/21 07:31 AM
11/25/21 07:31 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
So if someone is selling a whole engine for 300 bux that has the aluminum housing, I should buy it? I know parts are in short supply for these trucks but I don't want crap sitting around I might need someday. shruggy
Re: 99 Ram V10 thermostat [Re: redraptor] #2989038
11/25/21 02:34 PM
11/25/21 02:34 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If the tstat housing and timing cover are free of corrosion you’ll make $$ on that
Re: 99 Ram V10 thermostat [Re: J_BODY] #2989213
11/26/21 07:06 AM
11/26/21 07:06 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Actually, I was referring to things maybe I should be buying if I find it cheap as I recently purchased a V10 truck. Otherwise, people be makin' $$ on me!
