Tricking timing light to work on MSD #2986764
11/19/21 12:56 PM
11/19/21 12:56 PM
central il.
second 70 Offline OP
central il.
A friend brought over a cheap Harbor Freight dial back timing light that he said worked fine with MSD on his car. So I hooked it up to mine and it was useless. So I tell him it didn't work but I heard a trick that if you hook it up to a spare battery and not the one in the car it might work? He laughs and says that's the way he always uses it since his battery is in the trunk. Sure enough hooked it up to spare battery and it worked perfect.
Here's the light. https://www.harborfreight.com/timin...J5u-k9AIVY3NvBB20QQlJEAQYASABEgJ-TPD_BwE
Re: Tricking timing light to work on MSD [Re: second 70] #2986771
11/19/21 01:16 PM
11/19/21 01:16 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Bizzare, must be picking up a signal from the MSD it doesn't like, probably from the ground side would be my guess shruggy
Re: Tricking timing light to work on MSD [Re: TJP] #2986815
11/19/21 02:24 PM
11/19/21 02:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Interesting - never thought of that.
But I'm still using a simple timing light that dates back to the Nixon administration laugh2
Dead simple & idiot-proof, works on anything...
Re: Tricking timing light to work on MSD [Re: second 70] #2986844
11/19/21 03:08 PM
11/19/21 03:08 PM
I've done the same thing on my S/P car with a 7AL2, never thought about it not working but now this pointed out I will do that on any car I need to time with MSD ignition.
I do remember having issues with a Penske dial back light years ago and ended up buying battery powered brand to use on MSD, now they both work boogie
Thinks for the tip up bow
Re: Tricking timing light to work on MSD [Re: Cab_Burge] #2986878
11/19/21 04:00 PM
11/19/21 04:00 PM
moparx Online content
moparx  Online Content
interesting tip for sure. thank you for sharing ! up bow
beer
Re: Tricking timing light to work on MSD [Re: moparx] #2986927
11/19/21 06:16 PM
11/19/21 06:16 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I wonder if I’ve never had trouble with the ones I’ve tried because I get power by my starter. 🤔
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Tricking timing light to work on MSD [Re: pittsburghracer] #2986975
11/19/21 08:56 PM
11/19/21 08:56 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Same here...Never an issue with my Snap-on light... shruggy
...FAFO...
Re: Tricking timing light to work on MSD [Re: skicker] #2987043
11/20/21 12:54 AM
11/20/21 12:54 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Same here, no issues with my Snap On, but it's not a dial back. My battery is in the trunk also, and no alternator.
Re: Tricking timing light to work on MSD [Re: second 70] #2987067
11/20/21 07:04 AM
11/20/21 07:04 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Interesting discussion.
This has me wondering if the circuits inside a “dial back” timing light could be used to create a device to retard ignition tming while driving the vehicle.
Long ago MSD actually sold an aftermarket box that could retard timing up to 20 degrees using a knob mounted below the dash.
Re: Tricking timing light to work on MSD [Re: 360view] #2987073
11/20/21 07:34 AM
11/20/21 07:34 AM
PA.
"Little"John
"Little"John
PA.
Get a Grid ignition. Guys are cheating with them every week at the racetrack with them.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
