clutch rod clips ? #2986291
11/18/21 12:48 AM
11/18/21 12:48 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
where to get the u shaped clutch rod clips ?
thank you !
Re: clutch rod clips ? [Re: calrobb2000] #2986307
11/18/21 03:11 AM
11/18/21 03:11 AM
I have bought them from the local Dodge dealer, a dozen at a time up scope
Re: clutch rod clips ? [Re: Cab_Burge] #2986317
11/18/21 06:49 AM
11/18/21 06:49 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Brewers performance
Re: clutch rod clips ? [Re: fastmark] #2986330
11/18/21 08:49 AM
11/18/21 08:49 AM
md
mopars4ever Offline
mopars4ever  Offline
md
2405085 no longer available from mopar dealer
Re: clutch rod clips ? [Re: fastmark] #2986394
11/18/21 12:41 PM
11/18/21 12:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by fastmark
Brewers performance
X2
Re: clutch rod clips ? [Re: calrobb2000] #2986402
11/18/21 12:59 PM
11/18/21 12:59 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Don't forget to grab some of the thin nylon "washers" that are part of the assembly.
Make sure all your connection points of the Z-bar linkage are properly bent, so the connection points lay flat against each other. I had to massage my linkage to get the parts do that. Also, synthetic disc brake grease is the best lubricant I have found for those type of assemblies. It's very resistant to wash out, and remains slippery indefinitely.
