Re: clutch rod clips ?
[Re: calrobb2000]
#2986402
11/18/21 12:59 PM
11/18/21 12:59 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Don't forget to grab some of the thin nylon "washers" that are part of the assembly.
Make sure all your connection points of the Z-bar linkage are properly bent, so the connection points lay flat against each other. I had to massage my linkage to get the parts do that. Also, synthetic disc brake grease is the best lubricant I have found for those type of assemblies. It's very resistant to wash out, and remains slippery indefinitely.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
