Page 2 of 3 1 2 3
Re: 87 octane small block stroker? [Re: GO_Fish] #485114
10/02/09 09:23 PM
10/02/09 09:23 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I'm lucky here. Gas stations every where. All have 93 at the pump. Plenty of good preminum fuel around here.
Re: 87 octane small block stroker? [Re: Dougsmopars] #485115
10/02/09 09:36 PM
10/02/09 09:36 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
That is great! The mistake is that some people throw in higher octane then their engine needs, and that just reduces your horsepower (and costs you more money). Go with the lowest octane you can without detonation.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 87 octane small block stroker? [Re: GO_Fish] #485116
10/02/09 09:41 PM
10/02/09 09:41 PM
Dougsmopars Offline
Dougsmopars  Offline
Mine won't run on 87. Too much comp. too much cam and to much timing to make it run. Older build before quench was the buzz word. Runs great of 93 pings bad on 87. If i kick the timing back to stop the ping it has no balls left. My combo likes 22 degrees initial timing with 38 total.
Re: 87 octane small block stroker? [Re: Dougsmopars] #485117
10/02/09 09:51 PM
10/02/09 09:51 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
You have it right then for an old school build! My stock 340 GTS needs premium also, but my hybrid LA/Mag head 360 in my B'cuda runs fine on 87.
Re: 87 octane small block stroker? [Re: GO_Fish] #485118
10/03/09 07:48 AM
10/03/09 07:48 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
When Chrysler designed an engine for street towing with 87 octane fuel, they chose 8.4 static compression for the 1995 8L V10.
When Ford/Toyota designed an economy engine for 87 octane they gave the 2008 Ford Escape I4 a 11.7 to one static compression.
Obviously there is a wide range depending on the camshaft and combustion chamber and other factors.
The attached file is a graph from Japanese research showing how coolant temperature, ignition timing, and static compression ratio affect power and fuel economy:
Re: 87 octane small block stroker? [Re: 360view] #2985304
11/14/21 11:19 PM
11/14/21 11:19 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
popcorn whistling
Re: 87 octane small block stroker? [Re: skep419] #2985313
11/15/21 12:07 AM
11/15/21 12:07 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm a fan of building a street motor that you can successfully run on swill. I don't want to be in Wherethehellarewe, NV and find out that 87 octane is the only choice.
Re: 87 octane small block stroker? [Re: 6PakBee] #2985386
11/15/21 12:53 PM
11/15/21 12:53 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
I was looking into buying this rotating assembly 1-98111BI - Scat Engine Rotating Assemblies Summit Scat Kit
Not sure if it would run on 87 with Edelbrock 63cc heads and Felpro 1008's, Voodoo 60403 226 int./234 exh.
Re: 87 octane small block stroker? [Re: bigsbigelow] #2985429
11/15/21 02:19 PM
11/15/21 02:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Originally Posted by bigsbigelow
My grandfather has the MP 406 LA stroker in his Demon. It will run on 87 with no apparent knock. We normally use 93, though, because we haven't had time to dial in the timing to use 87 and feel safe doing it. <img src="/ubbthreads/images/graemlins/Twocents.gif" alt="" />
IIRC, those are 9.0 to 1 compression and big cams that would bleed compression too.
Re: 87 octane small block stroker? [Re: autoxcuda] #2985435
11/15/21 02:26 PM
11/15/21 02:26 PM
K
Kiddart Offline
Kiddart  Offline
K
watch the episode of Engine Masters regarding octane is a 10 to 1 Blueprint Motor. very eye opening to say the least.
Thank you
Kiddart
Re: 87 octane small block stroker? [Re: skep419] #2985439
11/15/21 02:28 PM
11/15/21 02:28 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have a 416 stroker with Edelbrock heads “63 cc” that we cc’d at 65 +/-1 cc. And 21cc Icon dish pistons with quench pad. Measured at 9.7:1 compression. It less than .035 quench. And has all chamber edges or potential hot spots deburred including chamber matched to bore. I have the older Comp 274-S cam with 236/241 @050 and .502/511”
I can’t run 87 octane. Maybe if I dialed timing way back.
Re: 87 octane small block stroker? [Re: kielbasa] #2985589
11/15/21 09:44 PM
11/15/21 09:44 PM
New York
64 Sportfury Offline
New York
I built a 318/390 stroker using Scat rods, crank, Icon pistons with quench pad. I topped it with EQ magnum heads which cc'd at 64.5. The calculated comp is 9.44, a measured .038 quench, paired with a 218 dur@.050 hyd roller, Edelbrock Pro Flo 4. The engine is in a 68 Coronet Wagon and I run it on 87 octane with 32 total timing. She doesn't like any more than that. I run a 2.76 rear gear and a 904. I built it with mpg and torque a priority. She does no bettter on 93 octane. I'm getting 13 mpg. Not great, but I'm still experimenting with the tune.
Re: 87 octane small block stroker? [Re: kielbasa] #2985615
11/15/21 10:46 PM
11/15/21 10:46 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Yes. Closed chamber modern head and appropriate cam and it can absolutely be done.
You may even find the engine wants a little less timing than you mentioned.
Re: 87 octane small block stroker? [Re: mgoblue9798] #2985690
11/16/21 08:24 AM
11/16/21 08:24 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
For what its worth my factory headed 360 with 9-1 comp has been 12.50@110 thru the mufflers on 87. In a 3775lb E body with a 4 speed.
Doug
Re: 87 octane small block stroker? [Re: dvw] #2985836
11/16/21 04:51 PM
11/16/21 04:51 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Doug
Care to share your build?
Re: 87 octane small block stroker? [Re: mgoblue9798] #2985898
11/16/21 09:10 PM
11/16/21 09:10 PM
Windsor, ON, Canada
Diplomat360 Online content
Diplomat360  Online Content
Windsor, ON, Canada
So how come no one is talking about the DCR?
I am trying to work through this question myself (another thread), but it would seem the Dynamic Compression Ratio is really what one needs to be looking at as that accounts for the valve timing events (which are courtesy of your cam).
As such, what I would love to know is the matching OCTANE<=>DCRs people have successfully ran with?
To re-hash that other thread:
previous 360 motor with 10.5:1 static and HE3844 flat tappet:
Quote
Static compression ratio of 10.5:1.
Effective stroke is 2.91 inches.
Your dynamic compression ratio is 8.72:1 .
Your dynamic cranking pressure is 182.97 PSI.
Your effective boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 0 PSI is 8.72 :1.
V/P (Volume to Pressure Index) is 162
Re: 87 octane small block stroker? [Re: autoxcuda] #2985949
11/16/21 11:28 PM
11/16/21 11:28 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Not questioning what you say, but it seems something might be off. Less than 10 to 1 with aluminum heads should be no problem with the cam you mentioned. What timing are you running? What is your AFR? Have you tried a colder plug? Also is your block an LA or Magnum?
Re: 87 octane small block stroker? [Re: mgoblue9798] #2985981
11/17/21 01:57 AM
11/17/21 01:57 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
IIRC 30 adv maybe 28. Can’t remember exactly
Don’t have an AFR meter
Yes tried colder plug
LA block
Don’t forget I live in California with California blend gas: low vapor pressure, no MTBE, etc
IMHO, That blanket statement about aluminum heads dropping compression a full point is overblown
How much measured compression are you running with aluminum heads and 87 octane?
Re: 87 octane small block stroker? [Re: mgoblue9798] #2985994
11/17/21 08:30 AM
11/17/21 08:30 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
.060" over 360, 9.0-1, Crane hyd roller HR-222/339-2S-12 IG, 1.6 Crane rockers giving .542/.563, LD340 intake w/ divider milled, 650 Holley DP, ported later model 360 heads w/2.02, TTI headers and 2.5" exh. The 12.50s were with slicks and a 4.30 gear. It's been 12.70@107 w/ 3.55 and old BFG drag radials. Always run with the air cleaner and exhaust. It has the factory 2.47 1st 4 speed and a Centerforce dual friction clutch.
Doug
Re: 87 octane small block stroker? [Re: dvw] #2986015
11/17/21 10:26 AM
11/17/21 10:26 AM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
Doug
Doug
Thanks for sharing. Also surprised this thread has this much action being as it was brought back from the dead drive 10/03/09 last post
Page 2 of 3 1 2 3
