Wheel Bearing Question #2983828
11/10/21 01:56 PM
11/10/21 01:56 PM
Orlando, FL
Challenger340Kid Offline OP
Orlando, FL
Hi,
I have a 2016 Dart. I did the brakes (pads and rotors) in December 2020, no issues. Recently took the car in and had new tires put on at the dealership. Got the car back, drove it less than 100 miles, and the "brake fluid low" light came on in the dash. I checked the reservoir, and sure enough, it was low on fluid. I didn't see any leaks, so I topped it off, drove it some more, and it went down again. Again checked driveway for leaks, etc. but found nothing. I put a little more fluid in, have driven it a few times, and checked it every day, it seems like a very slow leak, but I can see the level going down a little at a time.
I'm thinking that maybe I have a wheel bearing that is bad (washed the car a month ago, let it sit a few days before driving it, and had a lot of noise everytime I went to stop, initially figured it was just some surface rust that accumulated on the brakes that needed knocked off) but the more I think about that situation, and now the low brake fluid, maybe I do have a bad wheel bearing?
My question, with having done the brakes not quite a year ago (I've put less than 5k miles on the car between now and then), do I need to do brakes and or rotors if I replace the wheel bearings? What are your thoughts?
Thanks!
1972 Dodge Challenger 340 Auto 3.91 (B5 Blue)
2015 Dodge Challenger RT Plus (B5 Blue)
2016 Dodge Dart SXT Rallye (B5 Blue)
Re: Wheel Bearing Question [Re: Challenger340Kid] #2983862
11/10/21 04:59 PM
11/10/21 04:59 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
pretty sure one is not causing the other . . . . need to trace the leak from the master cylinder . . . maybe it is leaking past the master cylinder seal into the power booster ?? maybe check the vacuum hose to see if there is brake fluid in there ??? Pretty simple system (relatively), brakes - if master cylinder is not holding fluid, there is a leak in the system "somewhere" . . . maybe something with the ABS unit ?? . . . no way wheel bearings are going to cause master cylinder fluid level to drop . . . .
Re: Wheel Bearing Question [Re: a12rag] #2983925
11/10/21 08:06 PM
11/10/21 08:06 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Right. Bad bearings, very sloppy, can cause a soft pedal as the rotor push piston back. But that's not a fluid leak.
Angry white pureblood male
Re: Wheel Bearing Question [Re: a12rag] #2983967
11/10/21 09:37 PM
11/10/21 09:37 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
iagree
Re: Wheel Bearing Question [Re: TJP] #2983980
11/10/21 10:38 PM
11/10/21 10:38 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I had a Dart. IIRC, there was a recall because something could suck brake fluid out of the master through the motor. Was your car checked?
Re: Wheel Bearing Question [Re: slantzilla] #2984018
11/11/21 07:31 AM
11/11/21 07:31 AM
Orlando, FL
Orlando, FL
Slantzilla, this might be what you were talking about. From what I can tell, this is 2013-14's, mine is a 2016. Not to say it can't be the same / similar issue. Several links in the article I've posted..
https://www.dodge-dart.org/threads/brake-fluid-level-low-slave-cylinder.35289/
Re: Wheel Bearing Question [Re: Challenger340Kid] #2984019
11/11/21 07:32 AM
11/11/21 07:32 AM
Orlando, FL
Orlando, FL
I'll check the vacuum hose this weekend and report back. Thank you to everyone who has replied so far!
Re: Wheel Bearing Question [Re: Challenger340Kid] #2984033
11/11/21 08:40 AM
11/11/21 08:40 AM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
Unfortunately, there is a reason the Dart is/was not a popular car. Maybe multiple reasons.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Wheel Bearing Question [Re: oldjonny] #2984052
11/11/21 10:00 AM
11/11/21 10:00 AM
Orlando, FL
Orlando, FL
It's crazy, I bought it as a "beater" initially, and I've made the comment to several people about how much more I like it than I originally thought I would. I mean it's a turd for sure, I have a 2.0L 6 speed, but it's comfortable, and it was one of 3 options (Challenger, Dart, Viper) in 2016 that Mopar offered with a manual transmission, and I already had a challenger. I knew going in that it was a "cheap" or "cheaply made" car, but I mean honestly, everything today is cheap / plastic, and not made to last.
Re: Wheel Bearing Question [Re: Challenger340Kid] #2984059
11/11/21 10:31 AM
11/11/21 10:31 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The new Darts are not much car. I have bought one or two for resale, but won't again. There is a reason that Dodge dropped them rather quickly from the line.
As a side note, I will buy aftermarket brake rotors only when all else fails. They have quite a variation of quality and finish. Mostly not good. A good many need turned right out of the box and warp more readily than their O.E counterparts. Turning the originals (when possible) or finding usable original ones in the yards is the route we take.
Master, again and still
Re: Wheel Bearing Question [Re: DaveRS23] #2984074
11/11/21 11:37 AM
11/11/21 11:37 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
No need to replace brakes with a wheel bearing change. I had to do a DS wheel bearing on my 16 last year and it was a piece of cake. The only thing I had to borrow from a neighbor was the socket to remove the axle shaft nut. Everything else was straight forward. My 16 has been a great car.
Re: Wheel Bearing Question [Re: DaveRS23] #2984076
11/11/21 11:39 AM
11/11/21 11:39 AM
O
oldjonny Offline
oldjonny  Offline
O
Interesting...I had the opposite with my DD GM product. Factory rotors were junk in less than 30K and the aftermarket Chinese knock-offs have been great. I am on my 4th set, but 290K miles will do that (plus I'm not exactly easy on brakes, LOL)
Re: Wheel Bearing Question [Re: oldjonny] #2984080
11/11/21 12:08 PM
11/11/21 12:08 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I have a 2014 Dart 2.4 6 speed which I bought new and now has 104,000 miles.
It’s been a good reliable car, still looks new after 7 years of daily driving here in the rust belt. At this point I’d say it doesn’t owe me anything. I intend to keep it as my beater until it drops so I can keep my new Ram out of the salt.
Sorry some don’t like them, naysayers can enjoy their wonderful Hyundai’s I guess while I drive around in my crappy Mopar!
The hydraulic clutch system uses the brake master cylinder reservoir for its fluid supply, so if the brake system shows no evidence of leaks, I’d check the line from the clutch master cylinder to the clutch slave, and those 2 cylinders for evidence of being the source of your fluid loss. twocents
Re: Wheel Bearing Question [Re: oldjonny] #2984134
11/11/21 02:24 PM
11/11/21 02:24 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I am familiar with O.E. rotors failing. Google is your friend in these cases. The O.E.s use imported pieces too, obviously. And they occasionally have problems with them. But usually, the O.E. pieces are better than the parts store pieces. Not always, but usually. It is always best to Google particular problems to see if there is a wider problem. More information makes for better decisions.
Re: Wheel Bearing Question [Re: DaveRS23] #2984155
11/11/21 03:21 PM
11/11/21 03:21 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Factory rotors are junk. Even the vaunted Toyotas don’t have good ones. Years ago I simply walked into car quest and asked for the Canada made rotor for whatever I had at the time and that was the end of the issue. Well offshoring took care of that good solution. After years of frustration, I have settled on two options. EBC made in England and some even are made in the USA like they should be. You have to plan ahead and even if you do it can be hard to get them in your hands.
If I can’t wait for those, powerstop Chinese has been ok. It’s just I detest supporting China and do my best to shun them and their bs.
This year we cut it close, but the boat from England finally made it the week things were getting ugly on a car. I estimated maybe 3 days left before it had to be parked. Glad it made it, the EBC stuff has been awesome again.
I want my fair share
Re: Wheel Bearing Question [Re: SomeCarGuy] #2984238
11/11/21 07:02 PM
11/11/21 07:02 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I can't agree with that broad of a statement. I have seen too many O.E. rotors last the life of the vehicle given that no pads are worn to metal and maybe a turn or two. We just sold a Town and Country that had 240,000 miles and still had the original rotors. Had been turned once, maybe twice, I don't remember. It was one of our work vans we have had for over a decade.
Yes, some O.E rotors are crap, as bad as or worse than parts store pieces. But it is simply not true that they are all 'junk'.
Re: Wheel Bearing Question [Re: DaveRS23] #2984263
11/11/21 08:42 PM
11/11/21 08:42 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Here in our town, you can't get drums or rotors turned, anywhere. Everyone got rid the the lathes to turn the drums and rotors about 5 years ago.
That was probably for the better though. The last pair of rotors I had turned ended up being turned very poorly ( they were good, I just wanted them cleaned up a little). That left me with two warped rotors that cost $25 each to turn (on $30 each replacement made in the USA rotors). The quality of a turned drum or rotor has a lot to do with the condition of the machine doing the cutting, and the person operating the machine. Equipment in poor condition and/or a poorly trained operator does not make a good brake turning experience. Gene
Re: Wheel Bearing Question [Re: poorboy] #2984426
11/12/21 10:08 AM
11/12/21 10:08 AM
a12rag Offline
a12rag  Offline
Years and years ago when I was working in a shop, I learnt how to use the lathe to turn drums & rotors. I always only took off the least amount to clean things up . . . course, that was when drums and rotors had lots of meat to them and you could turn them a couple times . . . couple of machines I kinda wished I had bought at swap meets - brake lathe, and distributor machine . . . . maybe an old tire machine & balancer too . . . but then again, the shop at home barely keeps the cars in them, let alone all these machine wishes . . . .
Re: Wheel Bearing Question [Re: poorboy] #2984432
11/12/21 10:20 AM
11/12/21 10:20 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
We still have a place or two here that turn rotors. But we bought our own brake lathe so that we can control the quality because of issues like the ones you bring up. We occasionally turn rotors for people we know, but by and large, the lathe is for our own stuff. We have had to turn new, out-of-the-box rotors that were not available to us any other way.
And we have a tire changer and a balancer for the same reasons.
Re: Wheel Bearing Question [Re: a12rag] #2984434
11/12/21 10:36 AM
11/12/21 10:36 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
The last time I took the Ramcharger rotors in to be turned they'd been new on the previous brake job, so only one set of pads wore on them, no gouges. I was told they were too thin to turn so bought new ones again. Just for sh*ts and giggles I asked them to mic the new rotors, they were .001 ~ 0015 over MINIMUM turning thickness. Just normal wear from one set of pads makes them ineligible to be turned. So either don't bother to turn them or just plan on new ones every brake job. At least the chinesium rotors are affordable, especially considering you're not paying $20 ea. (It thnk it was $12 ~ 10 years ago?) to turn the old ones. It's no wonder turning drums and rotors is a dying thing.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
