Page 4 of 4 1 2 3 4
Re: TA/AAR Two-Nipple Crankcase Breather [Re: RareTA] #616036
03/06/10 01:18 PM
03/06/10 01:18 PM
MD
floyd Online content OP
floyd  Online Content OP
MD
I checked with the owner of the survivor (one-owner) plum crazy T/A. He said his car has the original single-nipple breather and the center carb bowl vents to the atmosphere. I believe his carb came with a short piece of hose off the bowl vent (several inches long). I've asked him to take a close-up pic and I'll post it when I get it. That's pretty solid info for me since his car was built the same day as mine and our VINs are very close.
That said, I'll probably run a 2-nipple on the car IF I ever get it done.
Re: TA/AAR Two-Nipple Crankcase Breather [Re: floyd] #616037
03/08/10 12:08 AM
03/08/10 12:08 AM
London Ontario Canada
SYDWAZ Offline
SYDWAZ  Offline
I am the original owner of an AAR. It has 42K and is unrestored. As Barry said mine has the open vent to the atmosphere and a single large spigot on the crankcase vent.
Re: TA/AAR Two-Nipple Crankcase Breather [Re: SYDWAZ] #616038
03/08/10 02:48 AM
03/08/10 02:48 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
This topic keeps coming up over and over again and I don't know if there is a real good answer. There is truth to both sides of the story.
Here is a strange one for everybody and I don't know if even Barry can even answer it. I came across a old T/A sitting in a field and this is the breather that was on this car.....
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: TA/AAR Two-Nipple Crankcase Breather [Re: Troy] #616039
03/08/10 03:25 AM
03/08/10 03:25 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
thats the correct breather for the T/A motors with the cross bolt mains
Re: TA/AAR Two-Nipple Crankcase Breather [Re: ademon] #616040
03/08/10 08:57 AM
03/08/10 08:57 AM
Pennsylvania
A0M397X Offline
A0M397X  Offline
Pennsylvania
Great disscusion. The only thing I can add is that many cars had open bowl vents in this time period. Most of my cars are AMC and all have atmospheric vents without any plumbing.
Re: TA/AAR Two-Nipple Crankcase Breather [Re: Troy] #616041
03/08/10 02:01 PM
03/08/10 02:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Some guy in CA got bored & made that one.
Re: TA/AAR Two-Nipple Crankcase Breather [Re: Alaskan_TA] #616042
03/09/10 07:02 AM
03/09/10 07:02 AM
Texas
bogusracer Offline
bogusracer  Offline
Texas
Made in CA. for breathing something more than fumes from a "Crank" Case. LOL
Re: TA/AAR Two-Nipple Crankcase Breather [Re: bogusracer] #616043
03/09/10 02:08 PM
03/09/10 02:08 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i just cap mine off. I dont need gas flooding onto the engine. had that happen on my truck once and WHOOOOOSH! it caught fire lickity split.
The holley 2 bbl 2300 has a fuel bowl vent already built in. it vents thru the hole in the front center of the air horn.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: TA/AAR Two-Nipple Crankcase Breather [Re: aarcuda] #616044
03/09/10 04:19 PM
03/09/10 04:19 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
If you cap it off at the carb you could get a high speed miss. You can starve the engine for fuel at the top end.
Re: TA/AAR Two-Nipple Crankcase Breather [Re: Troy] #616045
03/09/10 04:42 PM
03/09/10 04:42 PM
Shoreline, Washington
72roadrunnergtx Offline
The center carb external fuel bowl vent line nipple? The enclosed vent valve is closed off at any throttle position other than idle and off-idle. Plugging it off will have no effect high speed fuel mixtures. It is intended to be vented to the atmosphere if not plumbed to the breather cap or a charcoal canister however.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: TA/AAR Two-Nipple Crankcase Breather [Re: Troy] #616046
03/10/10 02:23 PM
03/10/10 02:23 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
the end carbs operate without a similar valved external vent. the end carbs only have the tube in the center of the air horn.... why wouldnt they need the same type of vent as the center carb?
and ya, doesnt the valved vent only open at idle and close when you give it gas???
Re: TA/AAR Two-Nipple Crankcase Breather [Re: aarcuda] #616047
03/10/10 02:28 PM
03/10/10 02:28 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
btw, there are TONS of holley carbs that do not have this valved vent line on them. the majority of 4bbl holley carbs just use the vent that is in the air horn.
why would a six pack carb need a special vent for the center? doesnt make sense. should operate the same as any old run of the mill holly 44bl
Re: TA/AAR Two-Nipple Crankcase Breather [Re: aarcuda] #616048
03/10/10 03:43 PM
03/10/10 03:43 PM
Every Mopar OEM Holley, including the early center six-pack carbs, has had an external fuel bowl vent valve of some sorts, either a small rubber “hat” over a hole or the later enclosed valve and nipple (E.C.S.) It is not intended to be/or replace the primary balanced bowl vent. On a street application it’s purpose is to provide, external to the air cleaner, another bowl vent path to atmospheric pressure thus ensuring, under hot at rest conditions, that pressures above the fuel can’t build during heat soak. Competition applications usually don’t have the same concerns and therefore carbs built for that purpose don’t have them. Aftermarket carburetors, including those from Holley, I’ve purchased over the years, designed for street/street-strip use, all had an external enclosed bowl vent valve. If not running an evaporative recovery system of some kind it is to be left open.
Blocking off or eliminating the external vent valve system will not alter the running performance at all in most cases, may contribute to hard starting hot however under curtain street use conditions.
Re: TA/AAR Two-Nipple Crankcase Breather [Re: 72roadrunnergtx] #616049
03/10/10 10:23 PM
03/10/10 10:23 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i can believe that. i was responding to the post that said the valved external vent was needed to prevent a high speed miss.
I know i have mine blocked off AND when its hot out side, and the engine is hot and has been sitting for 15 to 20 minutes, it doesnt like to start and sometimes spews gas out of the vent in the airhorn. now i know why
Re: TA/AAR Two-Nipple Crankcase Breather [Re: aarcuda] #2984127
11/11/21 02:06 PM
11/11/21 02:06 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Reviving this very old thread. Any idea what application this style 2 nipple breather was used on. Not familiar wit this style. Most of the 2 nipple breathers I have seen have a smaller nipple located toward the bottom. Could this design have shown up on some of the 340 & 440 6 pack applications?
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: TA/AAR Two-Nipple Crankcase Breather [Re: 70gtx440dana] #2984137
11/11/21 02:41 PM
11/11/21 02:41 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Barry’s reply to the original post in this thread still holds. 6 packs got one nipple or three nipple depending on the emission package the car was built with.
I bought an NOS 2 nipple years ago when I was gathering parts for my T/A thinking it was correct for my car.
After I found it wasn’t, I found it was only correct for something not very exciting, like maybe slant sixes. After a number of years trying to sell it, I finally found a buyer for my NOS cap, got $25 for it iirc.
Re: TA/AAR Two-Nipple Crankcase Breather [Re: Mastershake340] #2984205
11/11/21 05:38 PM
11/11/21 05:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I'll just leave this image right here......
1970
Re: TA/AAR Two-Nipple Crankcase Breather [Re: Alaskan_TA] #2984209
11/11/21 05:42 PM
11/11/21 05:42 PM
Lansing, MI
Lansing, MI
Thanks Barry...any idea what the breather in the above photos I attached was used for? I see the 2 port breathers shown in your photo all over the place. Have not seen this one before.
Re: TA/AAR Two-Nipple Crankcase Breather [Re: 70gtx440dana] #2984219
11/11/21 06:00 PM
11/11/21 06:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
What I showed above was for the first model year this type was used, with the lower 2nd nipple location.
Yours may be from a later model year?
Page 4 of 4 1 2 3 4
