twisted off exhaust manifold studs on 440? #298369
04/24/09 04:08 PM
04/24/09 04:08 PM
WI
61 NYer Convt Offline OP
WI
ive got a 68 superbee with a 440 in it. the motor is all in and i just bought a new set of headers. the drivers side went on fine and when i got to the passenger side i had 1 hole that i could thread a bolt in. all of the other holes have twisted off studs . i hate to pull the head off just to drill them out. being that the heads are cast iron, why couldnt a guy blow the studs out with a cuttin torch and re-tap the threads? any suggestions would be much appreciated. thanks
Re: twisted off exhaust manifold studs on 440? [Re: 61 NYer Convt] #298370
04/24/09 05:07 PM
04/24/09 05:07 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
The pass side is the worst side to work on. No room.
Cutting torch ? ... ?? .. you could try it .. but with no room to work afterwards ...how would you get a tap in there ?
In most of these cases I have heard-of and seen .. the head has to come off and the process of EDM has to be used to get the stud out cleanly.
Re: twisted off exhaust manifold studs on 440? [Re: IcorkSOAK] #298371
04/24/09 05:29 PM
04/24/09 05:29 PM
WI
WI
i was figuring on taking the pass side mount loose and jacking up that side of the engine. then for sure i could get a tap in there. im working on a real tight budget so i hate to have to buy head gaskets and all that. you wouldnt think it would hurt the cast by just blowing that crap out of there with a torch but i dunno.
Re: twisted off exhaust manifold studs on 440? [Re: 61 NYer Convt] #298372
04/24/09 05:32 PM
04/24/09 05:32 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
Even with the mount loose ... you can't jack-it-up that high if it is hooked to the trans.
IF you know how to work that torch well ... you can try it.
GOOD luck.
Re: twisted off exhaust manifold studs on 440? [Re: 61 NYer Convt] #298373
04/24/09 06:02 PM
04/24/09 06:02 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i would think and angle drill and easy out with some heat is the safest.
Re: twisted off exhaust manifold studs on 440? [Re: blownzoom440] #298374
04/24/09 06:13 PM
04/24/09 06:13 PM
WI
WI
getting a torch and easy out in there will be no prob but i was just kinda concerned if it would hurt the cast iron.
Re: twisted off exhaust manifold studs on 440? [Re: 61 NYer Convt] #298375
04/24/09 06:42 PM
04/24/09 06:42 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
careful with the easy out routine. You might be better off with some left handed drill bits. Many times the bolts will walk themselves out while drilling them out.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: twisted off exhaust manifold studs on 440? [Re: 61 NYer Convt] #298376
04/24/09 06:45 PM
04/24/09 06:45 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
This post scares me
I am truckless..
Re: twisted off exhaust manifold studs on 440? [Re: 340SHORTY] #298377
04/24/09 07:56 PM
04/24/09 07:56 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
There are a COUPLE of these topics going right now .... anyone know of a vendor that offers a QUALITY stud or bolt that will heat-cycle without falling apart like this ?
Re: twisted off exhaust manifold studs on 440? [Re: IcorkSOAK] #298378
04/24/09 08:05 PM
04/24/09 08:05 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I just slap antisieze on everything!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: twisted off exhaust manifold studs on 440? [Re: Rug_Trucker] #298379
04/25/09 08:41 AM
04/25/09 08:41 AM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
how many bolts are we talking???I would say 1 or 2,I would drill and tap.Otherwise pull the head.We centerpunch the bolt.Drilled it small,then stepped up to the inner thead size picked out the threads.Chased it with a tap.worked well.
Re: twisted off exhaust manifold studs on 440? [Re: IcorkSOAK] #298380
04/25/09 10:18 AM
04/25/09 10:18 AM
Fastenall sells a good replacements once you get it out.And i think I paid 30 cents a piece for the studs. There is no easy fix with the engine in the car. Mite have to pull the head or deal with a bad exhaust leak Good luck.
Re: twisted off exhaust manifold studs on 440? #298381
04/25/09 11:28 AM
04/25/09 11:28 AM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
You will be time and money ahead pulling the head. You may wind up having to take it to a machnine shop but even if you can get them out yourself it's a hundred times easier with the head on a work bench. DAMHIK!
Re: twisted off exhaust manifold studs on 440? #298382
04/25/09 11:55 AM
04/25/09 11:55 AM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
Is it a simple replacement or is this part a BETTER piece than the OEM ? ...and how so ?
Re: twisted off exhaust manifold studs on 440? #298383
04/25/09 01:21 PM
04/25/09 01:21 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
Bad exhaust leak!!! What about the bad water leak? All that you are going to do with that torch is harden whats left of the bolt to the point that nothing short of carbide will touch it (and you will prolly break a couple of them). That is if you don't nick the head itself. FYI the last one that I heated cracked over to the frost plug. Pull the head and drill them out. That gasket is cheap compared to a gasket and a head.
Randy
Re: twisted off exhaust manifold studs on 440? [Re: dodgefarmer] #298384
04/25/09 01:27 PM
04/25/09 01:27 PM
PA USA
flatiron Offline
flatiron  Offline
PA USA
Believe it or not try using a electric vibrating pencil holding it against the broken stud while pushing against it ccw
Re: twisted off exhaust manifold studs on 440? [Re: flatiron] #298385
04/25/09 01:43 PM
04/25/09 01:43 PM
When I took the old studs in to get a match for them.The fella told me they were grade 8 chromemoly and would handle the heat. I guess he would know better than me.Not sure if theyre better or not. But it took a while just to find a match so thats wut i went with.
Re: twisted off exhaust manifold studs on 440? #298386
04/25/09 04:41 PM
04/25/09 04:41 PM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
  There is a reason those are twisted off, They were SIEZED! IMHO a torch will make a big mess out of the whole deal. And if you twisted off grade 8 studs, doubtful an easy-out will work. Next time try some Aero-Kroil penetrant(good stuff). Save the headache and take it off. Drill them out, or have them wire EDMed out.Then put some copper anti-sieze on the new ones. I have been a Millwright for 25 years and believe you me, broken bolts/drills/taps/E-Z outs are some of the most nightmarish repairs.
Re: twisted off exhaust manifold studs on 440? #298387
04/25/09 05:32 PM
04/25/09 05:32 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
I don't think it is the actual heat that is the prob .. it the extreme-hot then the cold cycling that makes these studs so brittle.
Do you have a part # for these? ... I need a bunch of them ... the motorhomes, boat, cars etc.
These from the supplier you mentioned are CM ? ... I don't think that there is anything really special about the OEM ones.
Re: twisted off exhaust manifold studs on 440? [Re: IcorkSOAK] #298388
04/25/09 07:34 PM
04/25/09 07:34 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
My Bro who owned his own exhaust shop for 30 yrs and who i consider one of the best exhaust specialist anywhere said if you want to spoil the head...Go Ahead" !!!
he said with the head still on the engine in the car , its almost impossible to get a torch flame perfectly aligned with the bolt. he said if you use a cutting tip chances are you will slice into the threads and maybe even the water jacket. he has removed studs that have been twisted off 1/4 - 1/2 inch in the hole but used a mig welder to keep building up enough metal until it was above the face of the head and then with some heat and with "new" VISE GRIPS" remove the broken piece.
Other then that , you can go with the drill and "easy out"( stud extractor) and hope for the best .
