Re: twisted off exhaust manifold studs on 440?
[Re: dOc …]
#298371
04/24/09 06:29 PM
04/24/09 06:29 PM
Posts: 83 WI
61 NYer Convt
WI
i was figuring on taking the pass side mount loose and jacking up that side of the engine. then for sure i could get a tap in there. im working on a real tight budget so i hate to have to buy head gaskets and all that. you wouldnt think it would hurt the cast by just blowing that crap out of there with a torch but i dunno.
[Re: 61 NYer Convt]
#298375
04/24/09 07:42 PM
04/24/09 07:42 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
careful with the easy out routine. You might be better off with some left handed drill bits. Many times the bolts will walk themselves out while drilling them out.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: dOc …]
#298380
04/25/09 11:18 AM
04/25/09 11:18 AM
Fastenall sells a good replacements once you get it out.And i think I paid 30 cents a piece for the studs. There is no easy fix with the engine in the car. Mite have to pull the head or deal with a bad exhaust leak ![](/ubbthreads/images/graemlins/tsk.gif) Good luck.
#298382
04/25/09 12:55 PM
04/25/09 12:55 PM
Posts: 30,497 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
Fastenall sells a good replacements once you get it out.And i think I paid 30 cents a piece for the studs. There is no easy fix with the engine in the car. Mite have to pull the head or deal with a bad exhaust leak Good luck.
Is it a simple replacement or is this part a BETTER piece than the OEM ? ...and how so ?
#298383
04/25/09 02:21 PM
04/25/09 02:21 PM
Posts: 1,072 The Sunny Shuswap
dodgefarmer
The Sunny Shuswap
Bad exhaust leak!!! What about the bad water leak? All that you are going to do with that torch is harden whats left of the bolt to the point that nothing short of carbide will touch it (and you will prolly break a couple of them). That is if you don't nick the head itself. FYI the last one that I heated cracked over to the frost plug. Pull the head and drill them out. That gasket is cheap compared to a gasket and a head.
Randy
[Re: flatiron]
#298385
04/25/09 02:43 PM
04/25/09 02:43 PM
When I took the old studs in to get a match for them.The fella told me they were grade 8 chromemoly and would handle the heat. I guess he would know better than me.Not sure if theyre better or not. But it took a while just to find a match so thats wut i went with. ![](/ubbthreads/images/graemlins/shruggy.gif)
#298387
04/25/09 06:32 PM
04/25/09 06:32 PM
dOc …
Florida STAYcation
I don't think it is the actual heat that is the prob .. it the extreme-hot then the cold cycling that makes these studs so brittle.
Do you have a part # for these? ... I need a bunch of them ... the motorhomes, boat, cars etc.
These from the supplier you mentioned are CM ? ... I don't think that there is anything really special about the OEM ones.
[Re: dOc …]
#298388
04/25/09 08:34 PM
04/25/09 08:34 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
My Bro who owned his own exhaust shop for 30 yrs and who i consider one of the best exhaust specialist anywhere said if you want to spoil the head...Go Ahead" !!! he said with the head still on the engine in the car , its almost impossible to get a torch flame perfectly aligned with the bolt. he said if you use a cutting tip chances are you will slice into the threads and maybe even the water jacket. he has removed studs that have been twisted off 1/4 - 1/2 inch in the hole but used a mig welder to keep building up enough metal until it was above the face of the head and then with some heat and with "new" VISE GRIPS" remove the broken piece. Other then that , you can go with the drill and "easy out"( stud extractor) and hope for the best . ![](/ubbthreads/images/graemlins/beer.gif)
