Electrical problem, tracking suggestions #2982955
11/07/21 10:47 PM
11/07/21 10:47 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Son was driving our 70 Charger RT Sat. (we keep it at his house)
Gave me a call, said car died after a "POP", car would try to restart then die when key released.
I assumed ballast resistor and took a ride to where he was with a spare and my Fluke.
Well, resistor checked OK and new one didn't help.
Found a 15 A fuse blown, replaced it but same results. Had car flat bedded to his house, $90, not too bad.
I'm thinking ignition switch or shorted wire before the ballast??
So what would be the best way to test wiring tomorrow with my tester?
Charger has a Painless system we installed, been about seven years with no hiccups.
Thanks in advance, Joe
Re: Electrical problem, tracking suggestions [Re: jlatessa] #2982986
11/08/21 12:34 AM
11/08/21 12:34 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Gave me a call, said car died after a "POP", car would try to restart then die when key released.If it "firing" during cranking then "stops" when key released. Could be bad ig. switch with the "Run" wiring, or no power at ballast "run" side if dual ballast.Check for power at ballast terminals on the dist. & input sides. Pop is probably just a backfire when ignition was lost at speed.
Re: Electrical problem, tracking suggestions [Re: jlatessa] #2983003
11/08/21 02:43 AM
11/08/21 02:43 AM
Shorted normally means a hot wire is shorted to ground on most automotive circuits which normally ends up with melted wires, evidently not so on your car. up
It sounds like to me that you have a open, AKA broken connection, I would start at the ballast resistor normally run wire side and work back towards the ignition switch to find the open, maybe look first at the connection between the steering column harness and the harness under the dash feeding the firewall bullhead connector scope
Good luck, let us know what you find please, that will help others on here later scope wrench up
Re: Electrical problem, tracking suggestions [Re: Cab_Burge] #2983027
11/08/21 08:57 AM
11/08/21 08:57 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thanks guys, what I expected to hear.
No bulkhead with Painless, so that narrows the problem.
Since the fuse was blown, I'm suspecting the switch or the wiring past the fuse.
Reasonable logic?
Thanks, Joe
Re: Electrical problem, tracking suggestions [Re: Cab_Burge] #2983029
11/08/21 08:59 AM
11/08/21 08:59 AM
Andrewh Offline
Andrewh  Offline
I would start tracing the line of the fuse that blew.
I am pretty sure ignition wiring isn't fused like that. but could be wrong.
Sure it could be related, but I don't think it is the cause.
Re: Electrical problem, tracking suggestions [Re: Andrewh] #2983471
11/09/21 03:01 PM
11/09/21 03:01 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Found it! Open blue wire to ballast.
Wire got damaged apparently when we were using 12V supply from the blue for a trans temp. light.
All is good now.
Thanks to all for input...Joe
Re: Electrical problem, tracking suggestions [Re: jlatessa] #2983784
11/10/21 11:16 AM
11/10/21 11:16 AM
moparx Offline
moparx  Offline
glad it was a relatively simple fix ! up
beer
