Can you mix & match U-joint styles?
#2982577
11/06/21 11:21 PM
11/06/21 11:21 PM
Posts: 4,809 Castlegar, BC, Canada
That AMC Guy
Looking for a definitive answer. Two friends say yes, I say no.
(and by styles I mean if a driveshaft was machined to take the OUTSIDE clips, can it use a u-joint that uses an INSIDE clip? )
I'm down to putting the driveshaft in my '88 Ram. The driveshaft I was given by the P.O. is machined for outside clips, yet the yoke he gimme is for inside clips.
Do I have the wrong driveshaft? The wrong yoke??
I'm fairly certain I can't "convert" it to use the inside clip U-joints.
Currently, I have a driveshaft that takes outside clips and a yoke that takes inside clips. Local parts store and even Rock Auto list only inside clip U-joints.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Can you mix & match U-joint styles?
[Re: That AMC Guy]
#2982593
11/07/21 12:29 AM
11/07/21 12:29 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
Mopar normally used Detroit type inside retainer type U joints, I have seen some cars and maybe trucks that had Mechanix style with the external retainers. I'm pretty sure most Mopar cars that came with Dana 60 rear ends had Mechanix style U joints on the rear end pinion joints, not Detroits I think that there may be a combination adapter U joint also, maybe not
[Re: Cab_Burge]
#2982612
11/07/21 07:30 AM
11/07/21 07:30 AM
Posts: 5,953 ohio
ruderunner
ohio
Can you have a u joint with 2 caps inside clip and 2 caps outside clip? Absolutely. Iirc some 4wd front shafts have that arrangement at the pinion end.
If you're shaft is the correct length, measure the cap diameter and distance between clips. Sit down with a u joint catalog and see what number joint matches your measurements.
Angry white pureblood male
