Custom ground camshafts wait times? #2982547
11/06/21 08:58 PM
11/06/21 08:58 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
What kind of wait times are being experienced. SFT, SRT? I know the vendors shelves on off the shelf cams are getting thin.
America First!
Re: Custom ground camshafts wait times? [Re: carnut68] #2982596
11/07/21 12:46 AM
11/07/21 12:46 AM
Which cam grinder?
Call the ones you want to use and ask them scope twocents
I'm going to have Bullett regrind a BB solid roller steel cam I have that has two damaged lobes, I ask them earlier this year about it and they said then about two weeks turn around time to get it back to me on regular ground shipping from MS or LA, which ever state they are in, back up here to central OR shruggy
I'm waiting on a local customer to decide if he wants the motor or not so I can make sure and get the compression ratio and camshaft grind correct for his needs luck
Re: Custom ground camshafts wait times? [Re: Cab_Burge] #2982621
11/07/21 08:11 AM
11/07/21 08:11 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I just has Bullet Racing Cams Grind a new Solid Roller and got the cam in 2 weeks. Chuck at Bullet was great to work with. Chuck did recommend their roller lifters so I went them as well. Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Custom ground camshafts wait times? [Re: carnut68] #2982797
11/07/21 02:59 PM
11/07/21 02:59 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Just ordered a solid roller for the 572 Hemi. Tim said two weeks.
