Re: So who here has done a G3 with a roots blower on it?
[Re: fbs63]
#2982387
11/06/21 01:50 PM
11/06/21 01:50 PM
Posts: 1,541 USA
hudsonhornet7x
USA
[Re: Dragula]
#2982436
11/06/21 04:36 PM
11/06/21 04:36 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
Well Nitro Methane from Big Daddy and a 690hp 8-71 blown G3 Hemi aren't selling me on going from a G2 to a lowly G3....My NA G2 makes 840hp, a blown G3 should make more than that....Sad....Looking form someone who has done it, and made an appropriate HP level with it. I know you are talking old school blowers, but isn't the Hellcat 6.2 a roots blower ? Many of that style of gen3's making over 1200 hp & more
[Re: CSK]
#2982468
11/06/21 05:20 PM
11/06/21 05:20 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
Well Nitro Methane from Big Daddy and a 690hp 8-71 blown G3 Hemi aren't selling me on going from a G2 to a lowly G3....My NA G2 makes 840hp, a blown G3 should make more than that....Sad....Looking form someone who has done it, and made an appropriate HP level with it. I know you are talking old school blowers, but isn't the Hellcat 6.2 a roots blower ? Many of that style of gen3's making over 1200 hp & more One, yes, I am talking old school blowers... Two, doubt but one person on here is making that kind of steam even with the latest and greatest tech on it...I am looking at a more old school build to make 1000hp on good fuel and if anyone has done it. They say theses G3 heads are good, and with them limited to 426 cubes, that's a tall order to keep up with a NA big block...Probably 20lbs of boost to go that fast, so I am curious who has done it. Bet a ton of LS guys have.
[Re: Dragula]
#2982534
11/06/21 08:32 PM
11/06/21 08:32 PM
CSK
Pattison Texas
I see Alkydigger has a 10-71 set up for a G3, I am also curious of the outcome
[Re: Dragula]
#2982590
11/07/21 12:12 AM
11/07/21 12:12 AM
Posts: 2,255 IL
furious70
IL
Well Nitro Methane from Big Daddy and a 690hp 8-71 blown G3 Hemi aren't selling me on going from a G2 to a lowly G3....My NA G2 makes 840hp, a blown G3 should make more than that....Sad....Looking form someone who has done it, and made an appropriate HP level with it. I know you are talking old school blowers, but isn't the Hellcat 6.2 a roots blower ? Many of that style of gen3's making over 1200 hp & more One, yes, I am talking old school blowers... Two, doubt but one person on here is making that kind of steam even with the latest and greatest tech on it...I am looking at a more old school build to make 1000hp on good fuel and if anyone has done it. They say theses G3 heads are good, and with them limited to 426 cubes, that's a tall order to keep up with a NA big block...Probably 20lbs of boost to go that fast, so I am curious who has done it. Bet a ton of LS guys have. There are some serious guys on hellcat.org, or at least they have serious equipment. Again, that will be OEM or whipple stuff, not an 8-71, but might help you see where people are at.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Dragula]
#2982731
11/07/21 12:56 PM
11/07/21 12:56 PM
Posts: 1,839 NW Indiana
fbs63
NW Indiana
Bet a ton of LS guys have. [/quote] Why dont you just LS swap everything you have!? All you do is cry. You have been involved with Mopar long enough to know what it entails.
[Re: GTS340]
#2983718
11/10/21 07:09 AM
11/10/21 07:09 AM
Dragula
We decided since they raised the price of the G2 $1000 yesterday to go and build a roots blown 400 stroker for the new car and learn about roots combos from there. I tried calling MMX a bunch, and no answer lately, so this will get us started for now.. We know how to build an +800hp wedge that will live all season without any valve adjustments or really any maintenance except regular oil changes...So our plan is to be around 500 cubes, +9:1 compression, about .700 lift cam, Indy heads with big valves, and a Killer Ron's Terminator injection on meth with a TBS 8-71 and sneak up on a tune up that doesn't split the block in half. Later, the goal is to add an efi plate underneath the Ron's with injectors in it and run a TPS sensor on the Ron's and get away with pump gas and less boost on the street. This way we can switch back and forth and be legal in Nostalgia trim with the thought of doing Drag Week some day. And I guess I will save my ported G3 heads for another day...
[Re: fbs63]
#2984487
11/12/21 01:25 PM
11/12/21 01:25 PM
Dragula
Not legal in the class I run....And boost is boost, no?
[Re: Dragula]
#2984494
11/12/21 01:57 PM
11/12/21 01:57 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Not legal in the class I run....And boost is boost, no? No, boost is not boost. A more efficient blower will produce a denser charge at the same boost level because it does not heat the air as much as a less efficient blower at the same boost level.
[Re: Dragula]
#2985420
11/15/21 02:15 PM
11/15/21 02:15 PM
Posts: 1,552 Michigan
Kiddart
Dragula,
not sure why you are not seeing the 1000hp Gen 3's they are all over the place, sit and watch some the the Hemi challenge cars(New Hemi Challenge) these cars are getting it done. you tube is loaded with videos.
just sayin
Thank you Kiddart
[Re: Dragula]
#2988269
11/23/21 03:07 PM
11/23/21 03:07 PM
Posts: 1,541 USA
hudsonhornet7x
USA
