Re: oil pressure opinions
[Re: moretork03]
#2982284
11/06/21 08:32 AM
11/06/21 08:32 AM
Posts: 6,240 nowhere
Sniper
nowhere
have a 512 stroker with adjustable oil pump and the current pressure setting I have has got 90 psi at start up and idles at 30 when hot and runs from 40's to 60;s when giving it rpms My question is do you think 90 is in danger of blowing seals. I can turn it down to 70 at start up but then idles at 20 when hot and is that kind of low ? I'd be wondering why the bypass is letting it get to 90 myself.
[Re: Sniper]
#2982289
11/06/21 08:45 AM
11/06/21 08:45 AM
Posts: 1,383 Az
69hemibeep
Az
20 at hot idle is plenty, I also wonder about the bypass
1969 Hemi Roadrunner 2nd owner
[Re: B1MAXX]
#2982302
11/06/21 09:58 AM
11/06/21 09:58 AM
Posts: 129 wisconsin usa
moretork03
wisconsin usa
so since i can adjust it to the required 70/20 I should be fine,I guess I just have the setting to high at 90/30 ? is 90 to high ? Melling m63hv pump with milodon adjustable oil pressure valve VR1 20 50 oil tried there 10 30 but was going down to 15 at hot idle but immediately went into 40's with rpm's and had like 70 at cold start up but was thinking 15 might be to low
[Re: Moparite]
#2982318
11/06/21 10:31 AM
11/06/21 10:31 AM
Sniper
nowhere
Probably the bypass pressure goes up with running pressure. Might give more info on the pump. Only reason the bypass pressure would go up is of the oil pump is pumping so much oil that the bypass cannot dump the excess. 90 psi cold is too much, 70 psi warm is too much, imo. I like to see no more than 60 psi warm cruising. 15 psi at hot idle is fine. 20w50 is way too thick. I like to use just enough oil viscosity to get the pressure I want, any more is wasting HP. Typically I run 5w30. Which also cuts down on cold oil pressure.
[Re: DaveRS23]
#2982329
11/06/21 11:02 AM
11/06/21 11:02 AM
Posts: 2,856 Pattison Texas
CSK
Pattison Texas
I have a 440 source adjustable set up on my M63HV pump, the 63hv comes with a high pressure spring, I had to cut one coil off the spring to make the adjuster & pressure work correct.
[Re: moretork03]
#2982347
11/06/21 12:13 PM
11/06/21 12:13 PM
Posts: 1,705 central il.
second 70
central il.
have a 512 stroker with adjustable oil pump and the current pressure setting I have has got 90 psi at start up and idles at 30 when hot and runs from 40's to 60;s when giving it rpms My question is do you think 90 is in danger of blowing seals. I can turn it down to 70 at start up but then idles at 20 when hot and is that kind of low ? I have the same problem with my hemi. Stock Melling M63HV 10-30 mobile 1. 80psi cold idle 55 hot idle goes right up to 75 @ 2,000 hot? Can get over 90 hot at rpm's. Silver spring. I put on a M63H and it doesn't get over 45 psi hot pink spring. Would be happy at 65 max hot. I thought about changing springs but wouldn't the pink spring bypass at 45 even in the HV pump. Also thought about shimming regular pump spring but unsure how thick shim would have to be to increase pressure 20 psi. Suggestion's?
[Re: CSK]
#2982352
11/06/21 12:20 PM
11/06/21 12:20 PM
Posts: 19,388 north of coder
moparx
i like to see around 70-75 cold start, 20-25 hot idle, and 60[ish] at cruise. however, 10-15 at hot idle of 800-1000rpm works if it jumps to 40[ish] at a tickle of the gas pedal. i prefer a tad big bearing clearance and 10-40 or 15-40 oil. just my opinion. your mileage will vary.
[Re: second 70]
#2982354
11/06/21 12:23 PM
11/06/21 12:23 PM
CSK
Pattison Texas
I have the same problem with my hemi. Stock Melling M63HV 10-30 mobile 1. 80psi cold idle 55 hot idle goes right up to 75 @ 2,000 hot? Can get over 90 hot at rpm's. Silver spring. I put on a M63H and it doesn't get over 45 psi hot pink spring. Would be happy at 65 max hot. I thought about changing springs but wouldn't the pink spring bypass at 45 even in the HV pump. Also thought about shimming regular pump spring but unsure how thick shim would have to be to increase pressure 20 psi. Suggestion's? [/quote]
Start with a .020 or .030 shim & try it pink spring. will probably need a little more, but that is a good starting point, or cut one coil off the HP spring
[Re: CSK]
#2982362
11/06/21 12:54 PM
11/06/21 12:54 PM
Posts: 3,075 Michigan
A727Tflite
Are the rotors different thicknesses between the HV and non HV? I’m assuming they are but don’t want to assume.
Same design in both?
[Re: A727Tflite]
#2982372
11/06/21 01:16 PM
11/06/21 01:16 PM
CSK
Pattison Texas
The HV is thicker, more rotor
[Re: moretork03]
#2982388
11/06/21 01:59 PM
11/06/21 01:59 PM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
have a 512 stroker with adjustable oil pump and the current pressure setting I have has got 90 psi at start up and idles at 30 when hot and runs from 40's to 60;s when giving it rpms My question is do you think 90 is in danger of blowing seals. I can turn it down to 70 at start up but then idles at 20 when hot and is that kind of low ? just leave it as-is... pressure cold in meaningless and what seals will it blow out?... only need for messing with it is if you need every last 1/10 of a hp out of it... enjoy it
[Re: moretork03]
#2982413
11/06/21 04:13 PM
11/06/21 04:13 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
have a 512 stroker with adjustable oil pump and the current pressure setting I have has got 90 psi at start up and idles at 30 when hot and runs from 40's to 60;s when giving it rpms My question is do you think 90 is in danger of blowing seals. I can turn it down to 70 at start up but then idles at 20 when hot and is that kind of low ? I shoot for 10 lbs. per 1000 RPM with hot oil, 160F + I like and use thin oil, 5W20Wt so I have oil pressure as soon as the motor starts, my old pump gas 511 and later added .050 stroke to raise the compression ratio from 9.25 to 1 with iron 906 heads to 10.29 to 1 with aluminum Eddy RPM heads, that motor made 700 HP on pump swill and had between 18 to 20 lbs. oil pressure idling at 850 RPM in gear, it would have 30 lbs. at 1100 RPM and 65 lbs. at or above 6000 RPM with 180 F oil temps I beat the snot out of those parts and they lived forever Oil does two things for us, it cools and lubricates Do you know if your oil pressure gauges is dead on or can it be reading a little high or low AKA, your good with what you have now
[Re: Cab_Burge]
#2982447
11/06/21 04:50 PM
11/06/21 04:50 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
Roger dodger ... to our old from Bendover Toooo much oil pressure is actually worseEST .... ... than using tooooo many smilies in a single post
[Re: moretork03]
#2982514
11/06/21 07:05 PM
11/06/21 07:05 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
........ I have has got 90 psi at start up and idles at 30 when hot ......... I can turn it down to 70 at start up but then idles at 20 when hot I wounder why the idle pressure went from 30 down to 20.
