Re: How much does a 4.10 gear ratio car rev in 60 mph ?
[Re: 05dakota]
#2982117
11/05/21 04:13 PM
11/05/21 04:13 PM
Posts: 1,612 westerly, ri. usa
440lebaron
westerly, ri. usa
JACK up car rotate rear wheel one turn , driveshaft should turn 4.1 times
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Sniper]
#2982141
11/05/21 05:41 PM
11/05/21 05:41 PM
Posts: 1,553 Sweden
71redcuda
Sweden
[Re: 05dakota]
#2982205
11/05/21 09:26 PM
11/05/21 09:26 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
[Re: 71redcuda]
#2982359
11/06/21 12:49 PM
11/06/21 12:49 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
For reference, I just lowered my gear ratio to 4.30's with 28" tall rear tires. It spins 2500 rpm at 75 mph with the torque converter locked up in 4th (.67 OD). There are plenty of online calculators to plug your numbers into and get a reasonably accurate result.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Sniper]
#2983099
11/08/21 01:30 PM
11/08/21 01:30 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
becarefull with RPMs calculators... they don't consider the slippage AND the inertia of the car while riding, so just can take the rpms with engine pulling completelly the car.
there is a nice XLS table on the tech archives too.
and sometime ago somebody made an animated RPM calculator based on a 68/70 B body Rallye cluster where you could add a slippage % for the torque converter, as an estimate. Dunno if is still working.
as mentioned, with wheels on the air ( being SG, need to get both on the air ), a full turn of the axle/wheel will rotate the drive shaft the gear ratio. If single leg ( no SG ) you can raise just oen wheel andwill rotate half of the gear ratio
[Re: Sniper]
#2983105
11/08/21 01:54 PM
11/08/21 01:54 PM
NachoRT74
Valencia, España
I wouldn't say inertia is irrelevant. I have driven my Charger at 130 kmh ( 80 mph or so ) on highway just keeping the acc pedal to hold the speed and I was at 3200 rpms, while calculators give me 3800. and all that diff is not slippage, becauise slippage will give you the number backwards, with more RPMs than the calculators give
[Re: 1969ronnie]
#2984585
11/12/21 06:05 PM
11/12/21 06:05 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Hi 71 , my buddy has a 70 challenger with a 440 , 4 speed , Dana with 4.10s . Rear tires are 255-60-15 or G60-15 . Spins exactly 4,000 RPM at 70 mph . ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif) He gets passed by ricer cars and mini vans and HATES driving it on the highway ! If he would install a 5 or 6 speed overdrive he would be doing the passing and love it.
[Re: NachoRT74]
#2984667
11/12/21 09:50 PM
11/12/21 09:50 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
I wouldn't say inertia is irrelevant. I have driven my Charger at 130 kmh ( 80 mph or so ) on highway just keeping the acc pedal to hold the speed and I was at 3200 rpms, while calculators give me 3800. and all that diff is not slippage, becauise slippage will give you the number backwards, with more RPMs than the calculators give Inertia is irrelevant. Sniper is correct.
I want my fair share
[Re: SomeCarGuy]
#2984852
11/13/21 03:02 PM
11/13/21 03:02 PM
Posts: 8,184 Plymouth, MI
Blusmbl
Plymouth, MI
Inertia is irrelevant. Sniper is correct. It has a minor component on an automatic as it'll change the converter slippage. The slip percent will change going up or down a hill, as an example. On a manual it doesn't matter at all though. Another thing that will affect it is tire pressure and the tire itself. The tire squishes and loses diameter as you apply load to it, so the rpm to vehicle speed relationship changes.
